1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Encoders
To: [email protected]
Date: Tue, 21 Oct 2003 09:01:41 +0200
Robert,
Another couple of alternatives are the SSI550 (for up to 16 encoders) or the ECM504 (for up to 4 encoders), both from Kramert GmbH. The SSI550 requires an extra rack for interfacing to the encoder signals whereas the ECM504 has everything you need packaged into the VME board. See
www.sls.psi.ch/controls/hardware/
for links to data sheets for these modules in pdf format. There is a simple EPICS driver ... much more lightweight than handling any sort of RS232 protocol.
If you decide later to run your motors with encoder feedback, it's simply a case of setting up the RDBL field of the motor record.
David Maden
SLS Beamline Controls
Kurt A. Goetze wrote:
Robert,
If you are running synApps, OMS boards, and the "APS standard" motor
connection hardware, then the easiest way to read your encoder into EPICS
is to use the OMS VME58-4E card.  You also could use something like this
http://www.usdigital.com/products/ad4b/
and read the encoder counts with an EPICS generic serial record.
Kurt Goetze
APS/AOD/Beamline Controls
Robert Henning wrote:
I am trying to integrate some Renishaw encoders into EPICS and I am
trying to find a simple solution.  I don't have a lot of experience with
encoders so any comments or suggestions would be welcome.  At this point
I only want to use the encoders to verify my stepper motor position and
I was hoping for a simple RS232 interface.  I know this has been done
with other brands of encoders but I have not seen anything with the
Renishaw brand.  The encoders have "Differential signals in quadrature
to RS422 - output via line drivers".
I know I could use the OMS58-4 card but I think that is more then I
need.  I just want to be able to read in the information to EPICS for
now.
Thanks in advance,
Robert Henning
Operations Manager/Beamline Scientist/User Support Specialist
University of Chicago at Argonne
9700 South Cass Avenue
BioCARS - Building 434 B
Argonne, IL 60439
phone: (630) 252-0446
fax:   (630) 252-0443
Encoders Robert Henning
Re: Encoders Kurt A. Goetze
Prev: Re: Encoders Kurt A. Goetze
Next: RE: Encoders Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
