1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Command "seq" not found when running example ioc application
To: Andy Foster <[email protected]>, [email protected]
Date: Mon, 27 Oct 2003 07:35:46 -0600
Andy,
Thanks!!!!
Marty Kraimer
Andy Foster wrote:
Hi Marty, Steven,
The only small change I had to make to these
instructions was that I had to
add:
registrar(sncExampleRegistrar)
to myexampleApp/src/myExampleInclude.dbd
rather than remove the comment character as this line
was not in the file.
I think this is listed in "Known Problems" on the R3.14.4 web
page.
Cheers,
Andy
On Mon, 27 Oct 2003, Marty Kraimer wrote:
[email protected] wrote:
I'm hoping someone can help me with what is probably a very simple problem.
We have completely reinstalled epics base (14.4.3 and 14.3.4) and the
sequencer (2.0.7) onto a clean Red Hat Linux 9.0 environment and are trying
to get the example application described in Getting Started in the IOC
Developer's Guide up and going.  We have followed the installation
instructions to the letter in order to build and run EPICS, the Sequencer
and the sncExample.st application.
When we run the example using the supplied st.cmd file, it all loads into
the iocsh correctly until it gets to the command:
seq sncExample,"user=username"
At this point, we get the error:
st.cmd -- Line 28 -- Command seq not found
Everything appears to have built OK and when we run the demo example that
comes with the sequencer, it executes correctly, including correctly
starting up the sequencer.  I presume from this that EPICS and the
sequencer have built OK.
We are using gmake version 3.79.1 and have tried 3.80.0 as well, with no
luck.
Can anyone out there tell me why the seq command is not found when I run
this application?
Steve Banks
Australian Synchrotron Project
Department of Infrastructure
Level 18, 80 Collins Street
Melbourne   VIC   3000
tel:  +613 9655 6303
fax:  +613 9655 8666
web: www.synchrotron.vic.gov.au
Are you sure you followed the instructions to edit the Makefile in myexampleApp/src as described in section 2.2.4 of the 02OCT2003 Application Developer's Guide?
When you build do you see the sequence program being built?
For example on linux I see
converting ../sncExample.stt
/home/phoebus/MRK/epics/modules/soft/seq/bin/linux-x86/snc    ../sncExample.stt
-o sncExample.c
Marty Kraimer
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
Prev: Re: Command "seq" not found when running example ioc application Marty Kraimer
Next: RE: EPICS PV aliases? (rather long-winded) Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RADNET Sibley III, Coles
