1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS PV aliases? (rather long-winded)
To: "'Bob Dalesio'" <[email protected]>, "'Hoff, Lawrence'" <[email protected]>, <[email protected]>
Date: Mon, 27 Oct 2003 14:46:01 -0700
The portable server library supports process variable name aliasing. This
was put to good use in the CA gateway code which fully supports name
aliasing. I seem to recall that the Jefferson Lab directory service
implementation also supports this using the same interface in the portable
server library. It would certainly appear on the surface to be reasonable to
add similar capabilities to the records in the IOC.
All of this is also certainly closely related to discussions on integrating
LDAP, or some other directory services implementation supporting wild card
lookups, with EPICS. Nevertheless, it seems that the IOC should be
responsible for updating LDAP when it boots with the process variable names
- no mater whether they are alias or canonical names. Therefore, storing the
alias names in the database description appears to be the correct design
independent of our choice for future directory services.
Jeff
> -----Original Message-----
> From: Bob Dalesio [mailto:[email protected]]
> Sent: Friday, October 24, 2003 8:22 AM
> To: Hoff, Lawrence; [email protected]
> Subject: Re: EPICS PV aliases? (rather long-winded)
> Hi Larry,
> Well, it's something that we've discussed many times. It
> could be done fairly straight forwardly on the server. One
> of the reasons people use CDEV - is for the name aliasing.
> XAL also provides a name alias. Of course, both of these
> are on the server side. We've discussed this as a function
> of the name server as well. I am not sure if any of the
> name server currently support the feature.
> In short - I agree that it's a good idea. We need to get
> it into one of the releases.
> Bob
> On Fri, 24 Oct 2003 10:30:12 -0400
>   "Hoff, Lawrence" <[email protected]> wrote:
> >	For some time, I've been thinking about the subject of
> >aliases.
> >I regret now not bringing up the subject at the
> >Collaboration meeting
> >last week. I think there could have been good dialog. My
> >excuse for
> >bringing it up here and now is that ICALEPCS piqued my
> >interest again.
> >My real question is whether the idea of aliases is one
> >that has already
> >been discussed and settled, or whether there is interest
> >in pursuing
> >the idea. I especially hope its not just an existing
> >feature that I
> >am unaware of. We can, of course, bring it up at the next
> >Collaboration
> >Meeting. Here's my take on the subject:
> >	The RHIC control system supports aliases in the
> >client-side
> >directory services. We find this useful for two general
> >categories of
> >situations; transition between names, and multiplexing
> >records. The
> >former uses aliases only during the transition period.
> >The latter makes
> >permanent use of aliases.
> >	There are a couple situations that create the need for
> >transitioning between names:
> >	1) The naming standard changes, or was not correctly
> >understood
> >when the PVs were first named and deployed. Perhaps there
> >are EDM
> >screens or other applications deployed as well as the
> >IOC. In order
> >to change the PV names to the "correct" values, the IOC
> >must be rebooted
> >at the same time the new EDM screens are released (and
> >old EDM screens
> >reloaded). The coordination needed for this type of
> >release often leads
> >to "old" names living longer than desired. Using aliases,
> >both "old"
> >and "new" names can co-exist for a transition period
> >while old EDM
> >screens continue to be supported, and new screen are
> >rolled out.
> >	2) The mission of the PV changes over time. E.g. today
> >the
> >digitizer/scope/timing trigger is connected to one beam
> >diagnostic
> >system, but next month it is connected to a different
> >system. Another
> >variation on this theme is the idea of deploying/testing
> >IOCs before
> >the final "mission" of the H/W is specified. For RHIC we
> >took advantage
> >of that by deploying digitizers and function generators
> >with "generic
> >names" (funcGen1, funcGen2, adc1, adc2) for testing
> >purposes, well ahead
> >of when the PS group was ready to provide detailed wiring
> >diagrams.
> >As the "mission" was being finalized, we used aliases to
> >assign mission-
> >specific names to signals while retaining the "generic
> >name" in case the
> >PS group changed their minds as they wired up the
> >signals.
> >	The idea of multiplexing records has cropped up at SNS,
> >which
> >is my real impetus behind thinking about aliases.....
> >	There is a "virtual scope" application in use at SNS. It
> >is a
> >very sophisticated application, designed for high
> >performance, and
> >flexible configuration. One feature of this application
> >is that it can
> >display signals with different time bases (sample
> >frequency, trigger
> >times). It does this by associating time-PVs with the
> >signal-PV. This
> >association is done via the PV name. I.e. if the
> >signal-PV has a name
> >like "LINAC_BPM_004", the trigger time PV must have a
> >name like
> >"LINAC_BPM_004_trigger". The trouble with this scheme is
> >that there
> >can be dozens of signals that all share the same time
> >base. To support
> >the virtual scope, there needs to be one set of time-PVs
> >for every
> >signal-PV, even though they all contain identical values.
> >Of course,
> >this could be corrected in the virtual scope by
> >configuring it to use
> >specific time-PVs, rather than making constructions based
> >on the name
> >of the PV, but then the application loses its generality.
> >	Having a set of aliases which support the virtual scope,
> >but all
> >of which refer to the same underlying record removes
> >duplication and
> >preserves generality.
> >	OK, assuming that aliases are therefore "a good thing",
> >what
> >are the potential pitfalls, and how could one implement
> >them in a
> >server-side context, rather than in a directory service?
> >	Our RHIC experience indicates that there still should be
> >one
> >and only one "canonical" name for a record. I.e. as silly
> >as it sounds
> >when you ask "record, what is your name?" you should get
> >the same answer
> >whether you are using an alias or not. Otherwise one
> >cannot do
> >meaningful save/compare/restore operations
> >before/during/after a
> >transition period.
> >	Existing diagnostic tools should act in a natural way.
> >I.e.
> >a tool which should print out all the records in an IOC
> >should not
> >print out duplicates just because aliases are in effect
> >for that record.
> >However, tools which search for records by name should
> >work with either
> >the canonical name or the alias.
> >	Alias should be easy to configure and manage. There must
> >be
> >diagnostic tools which allow one to print out the set of
> >aliases in
> >effect.
> >	OK, with all that in mind, is it still
> >possible/reasonable
> >to implement aliases on the server-side (putting aside
> >for the moment
> >the question of whether it is a good idea to do so)? I
> >believe the
> >answer is "Yes, it is trivially easy to do so." For those
> >who care about
> >details, I'll support this claim with detailed
> >explanation of how I
> >think it can be done, and even some source code with a
> >"reference
> >implementation" at the end of this message.
> >	For now, I'll show some examples of how it might work.
> >Suppose there is a function called "addPvAlias" which
> >takes two
> >arguments. The first is the name of an existing record.
> >The second
> >is an alias name. Suppose there is also a diagnostic
> >function "dbla"
> >which prints out all the aliases on an IOC. Here's how it
> >might work:
> >VXWORKS>dbl
> >BNL_test:iocsns170:Time
> >value = 0 = 0x0
> >VXWORKS>dbla
> >value =  = 0x0
> >HOST>caget "larryTest1.NAME"
> >  larryTest2.NAME --- Invalid channel name
> >VXWORKS> addPvAlias "BNL_test:iocsns170:Time",
> >"larryTest1"
> >value = 33542248 = 0x1ffd068 = dbla + 0xa8
> >VXWORKS>dbl
> >value = 0 = 0x0
> >VXWORKS>dbla
> >alias: larryTest1, name: BNL_test:iocsns170:Time
> >value = 1 = 0x1
> >VXWORKS> dbpr "larryTest1"
> >ASG:                DESC: The current time
> >                 DISA: 0
> >DISP: 0             DISV: 1             NAME:
> >RVAL: 0             SEVR: NO_ALARM      STAT: NO_ALARM
> >     TPRO: 0
> >VAL: OCT 24 10:18:52
> >value = 0 = 0x0
> >larryTest1.NAME               BNL_test:iocsns170:Time
> >	The source code which follows implements this by adding
> >elements to the "PV directory", which point to existing
> >records.
> >I.e. it supports the idea of 1->N mapping between records
> >and
> >directory entries on the IOC, rather than a 1->1 mapping.
> >This
> >allows name lookup to work correctly, without changing
> >the
> >actual record count on the IOC. A separate list is
> >maintained of
> >aliases which have been successfully added to the IOC.
> >Here is the (hacked up) source code. This module can be
> >compiled
> >and loaded to a running EPICS system. To properly
> >implement aliases,
> >similar code would be implemented with the PV directory
> >module in
> >IOC core.
> >Thoughts?
> >-- Larry
> >#include <errno.h>
> >#include <stdio.h>
> >#include <stdlib.h>
> >#include <string.h>
> >static char *strdup(const char *s){
> >   char *dup = (char *) malloc(strlen(s)+1);
> >   if(dup) strcpy(dup, s);
> >   return dup;
> >/* #include <libCom/ellLib.h> */
> >struct ELLNODE {
> >   struct ELLNODE  *next;
> >   struct ELLNODE  *previous;
> >typedef struct ELLNODE ELLNODE;
> >struct ELLLIST {
> >   ELLNODE  node;
> >   int   count;
> >typedef struct ELLLIST ELLLIST;
> >extern ELLNODE *ellNext (ELLNODE *pNode);
> >/* #include <dbStatis/dbStaticPvt.h> */
> >struct dbRecordType; typedef struct dbRecordType
> >dbRecordType;
> >struct dbBase; typedef struct dbBase dbBase;
> >extern dbBase *pdbbase;
> >/* #include <dbStatis/dbBase.h> */
> >typedef struct dbRecordNode {
> >         ELLNODE         node;
> >         void            *precord;
> >         char            *recordname;
> >         int             visible; /* 0 */
> >}dbRecordNode;
> >typedef struct{
> >         ELLNODE         node;
> >         dbRecordType    *precordType;
> >         dbRecordNode    *precnode;
> >}PVDENTRY;
> >static ELLLIST aliasList; /* automatically initialized to
> >0 */
> >typedef struct {
> >   ELLNODE node;
> >   const char *name;
> >   const char *alias;
> >}aliasNode;
> >extern PVDENTRY *dbPvdFind(dbBase *pdbbase,char *name,int
> >lenName);
> >extern PVDENTRY *dbPvdAdd(dbBase *pdbbase,dbRecordType
> >*precordType,dbRecordNode
> >  *precnode);
> >PVDENTRY *addPvAlias(char *name, const char *alias){
> >   if(!name || !alias) { errno = -1; return NULL; }
> >   PVDENTRY *enode = dbPvdFind(pdbbase, name,
> >strlen(name));
> >   if(!enode) { errno = -1; return NULL; }
> >   dbRecordNode *recnode = (dbRecordNode *)
> >calloc(sizeof(dbRecordNode), 1);
> >   if(!recnode) { errno = -2; return NULL; }
> >   recnode->precord = enode->precnode->precord;
> >   recnode->recordname = strdup(alias);
> >   PVDENTRY *retval = dbPvdAdd(pdbbase,
> >enode->precordType, recnode);
> >   if(!retval) { errno = -3; return NULL; }
> >     aliasNode *anode = calloc(sizeof(aliasNode),1);
> >     if(!anode) { errno = -4; return NULL; }
> >     anode->name = enode->precnode->recordname;
> >     anode->alias = recnode->recordname;
> >     ellAdd(&aliasList, anode);
> >unsigned long dbla(void){
> >   aliasNode *enode = (aliasNode *) aliasList.node.next;
> >   while(enode){
> >     printf("alias: %s, name: %s\n", enode->alias,
> >enode->name);
> >     enode = (aliasNode *) enode->node.next;
> >   return aliasList.count;
> Bob Dalesio
> [email protected]
> 410 557 0297 Maryland
> 505 667 3414 Los Alamos
> 505 699 1632 Cell Phone
> 505 667 6087 Our Secretary (Lisa Marie)
Re: EPICS PV aliases? (rather long-winded) Bob Dalesio
Prev: Re: Command "seq" not found when running example ioc application Marty Kraimer
Next: RADNET Sibley III, Coles
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS PV aliases? (rather long-winded) Bob Dalesio
Next: Re: EPICS PV aliases? (rather long-winded) Alan K Biocca
