Folks,
I'm having a problem building base-3.14.4 on solaris-sparc-gnu in
libCom/misc. The OS is SunOS 5.8. Here's the error:
> gnumake
gnumake -C O.solaris-sparc-gnu -f ../Makefile TOP=../../..
T_A=solaris-sparc-gnu install
gnumake[1]: Entering directory
`/net/corvette/usr/local/epics/base-3.14.4/src/libCom/O.solaris-sparc-gn
u'
/usr/local/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_XOPEN_SOURCE=500
-DOSITHREAD_USE_DEFAULT_STACK -DUNIX -DSOLARIS=8
-D__EXTENSIONS__ -ansi -O3 -Wall -fPIC -I. -I..
-I../../../src/libCom/bucketLib -I../../../src/libCom/ring
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/env -I../../../src/libCom/error
-I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
-I../../../src/libCom/gpHash -I../../../src/libCom/logClient
-I../../../src/libCom/macLib -I../../../src/libCom/misc
-I../../../src/libCom/osi -I../../../src/libCom/taskwd
-I../../../src/libCom/timer -I../../../src/libCom/tsDefs
-I../../../include/os/solaris -I../../../include
..../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
..../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp: In method
`ipAddrToAsciiTransactionPrivate::~ipAddrToAsciiTransactionPrivate()':
..../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp:308: `UINT_MAX'
undeclared (first use this function)
..../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp:308: (Each
undeclared identifier is reported only once
..../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp:308: for each
function it appears in.)
gnumake[1]: *** [ipAddrToAsciiAsynchronous.o] Error 1
gnumake[1]: Leaving directory
u'
gnumake: *** [install.solaris-sparc-gnu] Error 2
UINT_MAX is not defined. UINT_MAX is defined in
/usr/include/sys/types.h, which is included via
ipAddrToAsciiAsynchronous.h -> osiSock.h -> os/solaris/osdSock.h ->
sys/types.h. However, it is only defined in sys/types.h if _KERNEL is
defined. Am I doing something wrong?
Mark Rivers
- Re: Problem building 3.14.4 on solaris-sparc-gnu Andrew Johnson
- RE: Problem building 3.14.4 on solaris-sparc-gnu Jeff Hill
R3.14.4 Linux IOC john sinclair
<2003>
<2003>
