1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Problem building 3.14.4 on solaris-sparc-gnu
To: "'Mark Rivers'" <[email protected]>, <[email protected]>
Date: Mon, 1 Dec 2003 14:47:58 -0700
I entered a bug report into mantis for this.
Jeff
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Monday, December 01, 2003 2:13 PM
> To: [email protected]
> Subject: Problem building 3.14.4 on solaris-sparc-gnu
> Folks,
> I'm having a problem building base-3.14.4 on solaris-sparc-gnu in
> libCom/misc.  The OS is SunOS 5.8. Here's the error:
> > gnumake
> gnumake -C O.solaris-sparc-gnu -f ../Makefile TOP=../../..
> T_A=solaris-sparc-gnu install
> gnumake[1]: Entering directory
> `/net/corvette/usr/local/epics/base-3.14.4/src/libCom/O.solaris-sparc-gn
> u'
> /usr/local/bin/g++ -c   -D_POSIX_C_SOURCE=199506L  -D_XOPEN_SOURCE=500
> -DOSITHREAD_USE_DEFAULT_STACK       -DUNIX  -DSOLARIS=8
> -D__EXTENSIONS__  -ansi  -O3  -Wall          -fPIC -I. -I..
> -I../../../src/libCom/bucketLib -I../../../src/libCom/ring
> -I../../../src/libCom/calc -I../../../src/libCom/cvtFast
> -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
> -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
> -I../../../src/libCom/env -I../../../src/libCom/error
> -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
> -I../../../src/libCom/gpHash -I../../../src/libCom/logClient
> -I../../../src/libCom/macLib -I../../../src/libCom/misc
> -I../../../src/libCom/osi -I../../../src/libCom/taskwd
> -I../../../src/libCom/timer -I../../../src/libCom/tsDefs
> -I../../../include/os/solaris -I../../../include
> ...../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
> ...../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp: In method
> `ipAddrToAsciiTransactionPrivate::~ipAddrToAsciiTransactionPrivate()':
> ...../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp:308:
> `UINT_MAX'
> undeclared (first use this function)
> ...../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp:308: (Each
> undeclared identifier is reported only once
> ...../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp:308: for each
> function it appears in.)
> gnumake[1]: *** [ipAddrToAsciiAsynchronous.o] Error 1
> gnumake[1]: Leaving directory
> u'
> gnumake: *** [install.solaris-sparc-gnu] Error 2
> UINT_MAX is not defined.  UINT_MAX is defined in
> /usr/include/sys/types.h, which is included via
> ipAddrToAsciiAsynchronous.h -> osiSock.h -> os/solaris/osdSock.h ->
> sys/types.h.  However, it is only defined in sys/types.h if _KERNEL is
> defined.  Am I doing something wrong?
> Thanks,
> Mark Rivers
Problem building 3.14.4 on solaris-sparc-gnu Mark Rivers
Prev: Re: Problem building 3.14.4 on solaris-sparc-gnu Andrew Johnson
Next: RE: Problem building 3.14.4 on solaris-sparc-gnu Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
