1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aiRecord, RVAL vs. VAL
To: [email protected], [email protected]
Cc: [email protected]
Date: Thu, 4 Dec 2003 14:52:36 -1000 (HST)
In a more recent update to devAscii, the returned value is written
directly into the record's VAL field, thereby bypassing the RVAL/ESLO
conversions. To do this the device support must also return the
"don't convert" status. This may be a better solution if you are
creating a device specific support layer.
AH
> X-Authentication-Warning: hotrats.mit.edu: [email protected]
[127.0.0.1] didn't use HELO protocol
> To: "Mark Rivers" <[email protected]>
> cc: <[email protected]>
> Date: Thu, 04 Dec 2003 17:42:35 -0500
> From: "Brian McAllister" <[email protected]>
> X-Mts: smtp
> List-Help: <http://www.aps.anl.gov/epics/tech-talk/index.php>
> >>> On 12/4/2003 at 16:30:38 CST, Mark Rivers wrote:
>   > I agree that having the RAW field be an integer is a limitation.  For
>   > example, I might want to read a voltage from a digital multimeter,
>   > which returns a floating point number, but then have that number
>   > converted to some other units, for example pressure, by the ai record
>   > conversion routine.  As it stands I think device support would have to
>   > do that conversion directly, it could not write into the RVAL field and
>   > ask the record to do the conversion.
> One work-around for this (which is used by devAscii, for instance) is to
> scale the value read from the device up in the device support so that it
> can be represented as an integer while maintaining useful precision, and
> then to scale it back down in the conversion to your desired units.
> - brian
Prev: Re: aiRecord, RVAL vs. VAL Brian McAllister
Next: Novice EPICS questions re yet another port David Kelly
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
