1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: process function of record waveform and CA (caput, caget)
To: [email protected], [email protected]
Date: Fri, 5 Dec 2003 09:48:26 -0600 (CST)
>	I wrote my device support for a waveform record. Record SCAN
>field is Passive.
>	I see next
>	When I use standard Epics's caput program (==dbpf IOC command?)
>IOC calls process function for this the record.
>	When I use standard Epics's caget program (==dbgf IOC command?)
>IOC doesn't like to call process function for the record. And I couldn't
>read current value.
>	Am I right?
Andrei,
If your version of 'caget' and 'caput' is built from the
epics/extensions/src/EzcaScan directory. You should be able to use
the caget and caput to get the waveform record.
On a UNIX system, you have to include the
 /usr/local/epics/extensions/bin/$HOST_ARCH in your search 'path'
 /usr/local/epics/extensions/lib/$HOST_ARCH in your 'LD_LIBRARY_PATH'
where
	$HOST_ARCH is 'solaris'       for EPICS 3.13
	$HOST_ARCH is 'solaris-sparc' for EPICS 3.14
If your 'path' and 'LD_LIBRARY_PATH' environment is not correctly set,
you will have problem with caget and caput. May be you should ask
your system adminstrator automatically set these up for EPICS users.
Ben-chin
Prev: Re: CA FLNK Luedeke Andreas
Next: Re: Novice EPICS questions re yet another port Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: process function of record waveform and CA (caput, caget) Marty Kraimer
Next: dynamical record loading/unloading and normal database Liyu, Andrei
