1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Network time server for vxWorks booting from Darwin
To: "MarkRivers" <[email protected]>
Cc: [email protected]
Date: Mon, 15 Dec 2003 07:44:04 +0900
>ioc13lab> iocClockSyncWithNTPserver: sntpcTimeGet S_sntpcLib_TIMEOUT
That error message problem was EPICS IOC dose not connected NTP Servers.
First you must checking your NTP servers alive and it?s better synchronization with GPS time.
Second route add, time zone, environment variable to boot script files.
My startup script "st.cmd" files examples.
#141.223.182.106 ? NTP server
#141.223.48.99 ? EPICS IOC subnet
routeAdd("141.223.182.106", "141.223.48.99")
putenv("TIMEZONE=KST::-540:000000:000000") #KOREA zone
putenv("EPICS_TS_MIN_WEST=-540")
putenv("EPICS_TS_NTP_INET=141.223.182.106") #PLS NTP server IP
# This comment helped Timo, who SLS Control people.
# Time stamp support software configuration:
# The parameters:
# 1. master_indicator: 1=master timing IOC, 0=slave, default is slave.
# 2. sync_rate_seconds: The clock sync rate in seconds, default 10 seconds.
# 3. clock_rate_hz: The frequency in hertz of the clock.
# Default 1000Hz for the event system
# and IOC's internal clock rate when soft timing is used.
# 4. master_port: The UDP port for a master to receive ts requests,
# default 18323.
# 5. slave_port: The UDP port for a slave to receive time stamps
# from a master.
# 6. time_out: UDP information request time out in milliseconds, default 250ms.
# 7. Operation mode: 0=normal operation, 1=force soft timing.
#more details read to EPICS IOC manuals
TSconfigure(1, 10, 1000,18323,18322,0,0)
and you type "date" again.
ioc:#01->date
Dec 15, 2003 07:40:41.320400198
value = 32 = 0x20 = ' '
Kiman Ha,
PLS Control Group
> -----Original message-----
> From: "MarkRivers"
> To: [email protected]
> Date: 12/15/2003(Mon)00:51
> Subject: Network time server for vxWorks booting from Darwin
> Folks,
> I am setting up an EPICS system where a vxWorks 5.4.2 IOC will boot from a Mac Darwin host. FTP and NFS are working fine, so the IOC boots OK. However, it then prints the message:
> which means that it was not able to get the time from the boot host. Typing "date" at the vxWorks prompt shows that indeed it has not set the date and time correctly.
> In the past I have successfully booted vxWorks IOCs from Windows systems by enabling the "timed" service provided by Hummingbird's inetd.
> I am confused about how to enable a time server on Darwin that the IOC can use. By default neither "ntpd" nor "timed" seem to be running (as judged from "ps -ax"). Manually starting "ntpd" and/or "timed" did not help, the IOC still does not get the time when it boots.
> Does anyone have an idea on what time server I should be running for vxWorks to be able to get the time, and how to correctly start that on Darwin?
> Thanks,
> Mark Rivers
Prev: Network time server for vxWorks booting from Darwin Mark Rivers
Next: Re: Network time server for vxWorks booting from Darwin Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Network time server for vxWorks booting from Darwin Eric Norum
Next: SBS VIPC616 IP Carrier Ned Arnold
