1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Network time server for vxWorks booting from Darwin
Cc: [email protected]
Date: Mon, 15 Dec 2003 08:33:51 -0600
Mark Rivers wrote:
Ernest,
Also, check Darwin for a ntp configuration file. There may be a default security level just like in LINUX:
That was basically the problem. With the default settings of ntpd on Darwin, and with the default ntp.conf, authentication is enabled. I have now copied our Linux ntp.conf file to the Darwin system, and it has a line "authenticate no". Restarting ntpd to use that file fixed the problem. I also realize now that my boot host does not actually have to provide ntp time, I can set the environment variable EPICS_TS_NTP_INET to point to another time server.
You could also specify the NTP server in a DHCP option field. This might be easier than messing around with environment variables.
-- Eric Norum [email protected] Advanced Photon Source Phone: (630) 252-4793 Argonne National Laboratory
RE: Network time server for vxWorks booting from Darwin Mark Rivers
Prev: Re: about edm1-9-6 Andy Foster
Next: SBS VIPC616 IP Carrier Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Network time server for vxWorks booting from Darwin Mark Rivers
Next: Re: Network time server for vxWorks booting from Darwin hkm
