1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: SBS VIPC616 IP Carrier
To: "Ned Arnold" <[email protected]>, "APS tech-talk" <[email protected]>
Date: Mon, 15 Dec 2003 11:49:49 -0600
Ned,
> We are experiencing some unusual behavior in an ioc with an AB 6008
> scanner and a SBS VIPC616 IP Carrier. We also remember some
> rumors about the VIPC616 IP carrier board not playing nicely with
other
> VME cards in the same crate. Advice such as "make sure it is to the
left of the AB
> Scanner" has been informally distributed, but has not resolved this
> problem.
I have 7 IOCs with VIPC616 IP carriers, and one that also has the AB
6008 scanner.  That IOC has had no problems with the two modules both
installed.  By chance the VIPC616 is to the left of the AB scanner, we
never tried it the other way.  Several of my IOCs have 2 VIPC616 boards
installed.
The only problems that I have seen:
- If we use the SBS IP-488 GPIB IP module, then we get frequent error
messages about uninitialized interrupts when we talk over the GPIB.
- I recently tried a configuration with 2 SBS IP-Octals (RS-232
modules), each in IP Slot A on each of 2 VIPC616 modules.  This led to
"Work queue panic overflow" and reboot of the IOC each time I booted.
It could be a problem with my configuration script, but I don't think
so.  Moving the second IP-Octal module into Slot D on the first VIPC616
worked around the problem.  It's on my list of problems to track down.
Mark Rivers
Prev: SBS VIPC616 IP Carrier Ned Arnold
Next: RE: Spurious link alarms generated? J. Frederick Bartlett
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: mosub record and R3.14 Kevin Tsubota
