1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: compile error of EPICS 3.14.4 under windows
To: [email protected]
Cc: [email protected]
Date: Tue, 13 Jan 2004 08:54:43 +1100
DongJun,
Also, all of the "unknown option" warnings that you are seeing can be
prevented by editing the file CONFIG_SITE.win32-x86.win32.x86 in the
directory \base\configure\os and uncommenting the lines in that file.
Note also that if you choose to download and build GNU Make 3.80 (the
latest version) from www.gnu.org there is a bug which will prevent it from
building unless you follow the instructions in:
http://savannah.gnu.org/bugs/index.php?func=detailitem&item_id=1687
This simply adds hash.obj into the list of files to link.
Steve Banks
Australian Synchrotron Project
Department of Infrastructure
Level 18, 80 Collins Street
Melbourne   VIC   3000
tel:  +613 9655 6303
fax:  +613 9655 8666
web: www.synchrotron.vic.gov.au
                      Janet Anderson
                      <[email protected]>        To:       [email protected], [email protected]
                                               cc:
                      13/01/04 03:09 AM        Subject:  Re: compile error of EPICS 3.14.4 under windows
You need GNU make version 3.78.1 or later. The version you are using
does not understand the "call" function.
Janet
dong-jun park wrote:
> Dear sirs,
> I'm beginer of EPICS and having problems building 3.14.4 under Windows
XP.  I have Windows XP with
> Perl, Tornado 2.0.2 for VxWorks and VC++ 6.0 installed.
> Target arch is the vxWorks-ppc604, host arch is the win32-x86
> When make encounters the first cl command it returns the following
errors:
> make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
> make[3]: Entering directory `D:\EPICS\base\src\makeBaseExt\O.win32-x86'
> make[3]: Nothing to be done for `install'.
> make[3]: Leaving directory `D:\EPICS\base\src\makeBaseExt\O.win32-x86'
> make -C O.vxWorks-ppc604 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc604
install
`D:\EPICS\base\src\makeBaseExt\O.vxWorks-ppc604'
> make[2]: Leaving directory `D:\EPICS\base\src\makeBaseExt'
> make -C libCom install
> make[2]: Entering directory `D:\EPICS\base\src\libCom'
> make[3]: Entering directory `D:\EPICS\base\src\libCom\O.win32-x86'
> cl -c              /nologo /D__STDC__=0  /Ox /GL   /W3 /w44355       /MD
> Command line warning D4002 : ignoring unknown option '/GL'
> Command line warning D4002 : ignoring unknown option '/w44355'
> Command line error D2003 : missing source filename
> make[3]: *** [bucketLib.obj] Error 0x2
> make[3]: Leaving directory `D:\EPICS\base\src\libCom\O.win32-x86'
> make[2]: *** [install.win32-x86] Error 0x2
> make[2]: Leaving directory `D:\EPICS\base\src\libCom'
> make[1]: *** [libCom.install] Error 0x2
> make[1]: Leaving directory `D:\EPICS\base\src'
> make: *** [src.install] Error 0x2
> what is the way to fix this problem ?
> Best Regards,
> DongJun Park
Prev: RE: PV reconnect logic question Jeff Hill
Next: Re: Choice of Power PC VME cards Korhonen Timo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: compile error of EPICS 3.14.4 under windows Janet Anderson
Next: RE: compile error of EPICS 3.14.4 under windows Liyu, Andrei
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
