1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: compile error of EPICS 3.14.4 under windows
To: [email protected], [email protected]
Date: Mon, 12 Jan 2004 10:09:30 -0600
You need GNU make version 3.78.1 or later. The version you are using
does not understand the "call" function.
Janet
dong-jun park wrote:
> Dear sirs,
> I'm beginer of EPICS and having problems building 3.14.4 under Windows XP.  I have Windows XP with
> Perl, Tornado 2.0.2 for VxWorks and VC++ 6.0 installed.
> Target arch is the vxWorks-ppc604, host arch is the win32-x86
> When make encounters the first cl command it returns the following errors:
> make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
> make[3]: Entering directory `D:\EPICS\base\src\makeBaseExt\O.win32-x86'
> make[3]: Nothing to be done for `install'.
> make[3]: Leaving directory `D:\EPICS\base\src\makeBaseExt\O.win32-x86'
> make -C O.vxWorks-ppc604 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc604 install
> make[3]: Entering directory `D:\EPICS\base\src\makeBaseExt\O.vxWorks-ppc604'
> make[3]: Leaving directory `D:\EPICS\base\src\makeBaseExt\O.vxWorks-ppc604'
> make[2]: Leaving directory `D:\EPICS\base\src\makeBaseExt'
> make -C libCom install
> make[2]: Entering directory `D:\EPICS\base\src\libCom'
> make[3]: Entering directory `D:\EPICS\base\src\libCom\O.win32-x86'
> cl -c              /nologo /D__STDC__=0  /Ox /GL   /W3 /w44355       /MD
> Command line warning D4002 : ignoring unknown option '/GL'
> Command line warning D4002 : ignoring unknown option '/w44355'
> Command line error D2003 : missing source filename
> make[3]: *** [bucketLib.obj] Error 0x2
> make[3]: Leaving directory `D:\EPICS\base\src\libCom\O.win32-x86'
> make[2]: *** [install.win32-x86] Error 0x2
> make[2]: Leaving directory `D:\EPICS\base\src\libCom'
> make[1]: *** [libCom.install] Error 0x2
> make[1]: Leaving directory `D:\EPICS\base\src'
> make: *** [src.install] Error 0x2
> what is the way to fix this problem ?
> Best Regards,
> DongJun Park
compile error of EPICS 3.14.4 under windows dong-jun park
Prev: Re: Choice of Power PC VME cards Andrew Johnson
Next: RE: PV reconnect logic question Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: compile error of EPICS 3.14.4 under windows dong-jun park
Next: Re: compile error of EPICS 3.14.4 under windows Steven . Banks
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
