1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: compile error of EPICS 3.14.4 under windows
To: "EPICS Tech-Talk" <[email protected]>
Date: Mon, 12 Jan 2004 18:17:44 +0900
Dear sirs,
I'm beginer of EPICS and having problems building 3.14.4 under Windows XP.  I have Windows XP with
Perl, Tornado 2.0.2 for VxWorks and VC++ 6.0 installed.
Target arch is the vxWorks-ppc604, host arch is the win32-x86
When make encounters the first cl command it returns the following errors:
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory `D:\EPICS\base\src\makeBaseExt\O.win32-x86'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `D:\EPICS\base\src\makeBaseExt\O.win32-x86'
make -C O.vxWorks-ppc604 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc604 install
make[3]: Entering directory `D:\EPICS\base\src\makeBaseExt\O.vxWorks-ppc604'
make[3]: Leaving directory `D:\EPICS\base\src\makeBaseExt\O.vxWorks-ppc604'
make[2]: Leaving directory `D:\EPICS\base\src\makeBaseExt'
make -C libCom install
make[2]: Entering directory `D:\EPICS\base\src\libCom'
make[3]: Entering directory `D:\EPICS\base\src\libCom\O.win32-x86'
cl -c              /nologo /D__STDC__=0  /Ox /GL   /W3 /w44355       /MD
Command line warning D4002 : ignoring unknown option '/GL'
Command line warning D4002 : ignoring unknown option '/w44355'
Command line error D2003 : missing source filename
make[3]: *** [bucketLib.obj] Error 0x2
make[3]: Leaving directory `D:\EPICS\base\src\libCom\O.win32-x86'
make[2]: *** [install.win32-x86] Error 0x2
make[2]: Leaving directory `D:\EPICS\base\src\libCom'
make[1]: *** [libCom.install] Error 0x2
make[1]: Leaving directory `D:\EPICS\base\src'
make: *** [src.install] Error 0x2
what is the way to fix this problem ?
Best Regards,
DongJun Park
compile error of EPICS 3.14.4 under windows dong-jun park
Re: compile error of EPICS 3.14.4 under windows Janet Anderson
Prev: RE: Problem linking a Channel Access application on Windows using Visual Studio Steven . Banks
Next: compile error of EPICS 3.14.4 under windows dong-jun park
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Running epics in background in linux Eric Williams
