1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Running epics in background in linux
To: Rok Sabjan <[email protected]>
Cc: [email protected]
Date: Wed, 28 Jan 2004 10:56:39 -0800
Rok,
I don't know if this applies to your hardware setup, but I set our IOC to run on one of the virtual terminals on our Linux box. I did this by modifying /etc/inittab by first commenting out the old entry for tty6 and then adding:
ioc:345:respawn:/bin/su -l bl72 </dev/tty6 >/dev/tty6
bl72 is the account for the IOC, and has a .cshrc file set up in its home directory to start the st.cmd file.
If you don't have virtual terminals, you should be able to redirect I/O to some other device, a file, or /dev/null.
eric
Rok Sabjan wrote:
Hi all!
I have an interesting question. How to run EPICS application on a linux box in a background. The box is actually contains a strong-arm processor with all the data (+EPICS) stored in the flash. I would like to get EPICS started as soon as I turn on the machine. But if I write a script and put it into /etc/init.d/S99epics, the application starts and then immediately ends.
I cannot use Dirk Zimoch's shellbox.tcl, as I have no tcl. I have also no screen program now. Everything else works very well on this platform, including serial device control with (for now) gpibCore.
Can anyone give me a clue about this, please. Should we patch EPICS a bit or is this solveable with linux tricks?
Cheers,
Rok
Running epics in background in linux Rok Sabjan
Prev: Definitions of RELEASE_ variables Chris Mayer
Next: WINSOCK Error 10055 Steven . Banks
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Running epics in background in linux Brian McAllister
Next: compile error of EPICS 3.14.4 under windows dong-jun park
