>>> On 1/10/2004 at 14:37:45 +0100, Rok Sabjan wrote:
> I have an interesting question. How to run EPICS application on a linux
> box in a background. The box is actually contains a strong-arm
> processor with all the data (+EPICS) stored in the flash. I would like
> to get EPICS started as soon as I turn on the machine. But if I write a
> script and put it into /etc/init.d/S99epics, the application starts and
> then immediately ends.
Look at the "screen" utility. It comes with Redhat Linux, and probably
most flavors. If you don't have it, it should be easy to find on the
net.
The command we are using is
screen -d -m <ioc executable> <ioc startup file>
This starts screen, with EPICS running, then detaches from the terminal.
Later, you can re-attach (from the same tty, or any other) with
screen -r
All output from the IOC while detached will be captured and can be reviewed
when you re-attach.
NAME
screen - screen manager with VT100/ANSI terminal emulation
SYNOPSIS
screen [ -options ] [ cmd [ args ] ]
screen -r [[pid.]tty[.host]]
screen -r sessionowner/[[pid.]tty[.host]]
DESCRIPTION
Screen is a full-screen window manager that multiplexes a
physical terminal between several processes (typically
interactive shells).
There is a scroll-back history buffer for each virtual
terminal and a copy- and-paste mechanism that allows
moving text regions between windows.
When screen is called, it creates a single window with a
shell in it (or the specified command) and then gets out
of your way so that you can use the program as you nor-
mally would. Then, at any time, you can create new (full-
screen) windows with other programs in them (including
more shells), kill existing windows, view a list of win-
dows, turn output logging on and off, copy-and-paste text
between windows, view the scrollback history, switch
between windows in whatever manner you wish, etc. All win-
dows run their programs completely independent of each
other. Programs continue to run when their window is cur-
rently not visible and even when the whole screen session
is detached from the user's terminal.
Brian McAllister Controls Programmer/Beam Physicist
[email protected] MIT-Bates Linear Accelerator
(617) 253-9537 Middleton, MA
- Running epics in background in linux Rok Sabjan
RE: Problem linking a Channel Access application on Windows using Visual Studio Steven . Banks
<2004>
Re: Running epics in background in linux Eric Williams
<2004>
