1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Possible bug in registerRecordDeviceDriver.pl
To: [email protected]
Date: Fri, 23 Jan 2004 09:17:39 -0500
I get the following error loading a library file on vxWorks/Epics 3.14.4:
cd timingbin
value = 0 = 0x0
ld<timingLib.munch
Undefined symbol: p (binding 1 type 0)  <<<<<<<<<<<<<<<<<<<<<
value = 28536800 = 0x1b36fe0
cd timing
value = 0 = 0x0
dbLoadDatabase("dbd/timing.dbd",0,0)
value = 0 = 0x0
timing_registerRecordDeviceDriver(pdbbase)
program
Exception current instruction address: 0x01b47334
Machine Status Register: 0x0008b030
Condition Register: 0x44200082
Task: 0x1b51b18 "tShell"
In timing.dbd I have:
driver (drvV124S)
device (ai,       VME_IO,   devAiV124S,      "Timing Gate")
#registrar("timingSubs") <<<<<<<<<<<<<<<<<<<<< Commented out
And from that   registerRecordDeviceDriver.pl  generates:
epicsShareExtern void (*p)(void);   <<<<<<<<<<<<<<<<<<<<<<<<
int timing_registerRecordDeviceDriver(DBBASE *pbase)
    int i;
    for(i=0; i< 11;  i++ ) {
        if(registryDeviceSupportFind(deviceSupportNames[i])) continue;
        if(!registryDeviceSupportAdd(deviceSupportNames[i],devsl[i])) {
            errlogPrintf("registryDeviceSupportAdd failed %s\n",
                deviceSupportNames[i]);
            continue;
    for(i=0; i< 1;  i++ ) {
        if(registryDriverSupportFind(driverSupportNames[i])) continue;
        if(!registryDriverSupportAdd(driverSupportNames[i],drvsl[i])) {
            errlogPrintf("registryDriverSupportAdd failed %s\n",
                driverSupportNames[i]);
            continue;
    (*p)();   <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    return(0);
The call to (*p)() generates the bus error and the unresolved link error.
The registrar line was commented out since I hadn’t actually completed the registrar function for that source file.  Apparently some pass that registerRecordDeviceDriver.pl made on the dbd file counted the line has having a registrar spec but didn’t pick up its argument.  The work around is to misspell “registrar”.
Re: Possible bug in registerRecordDeviceDriver.pl Kay-Uwe Kasemir
Prev: RE: ? initHookRegister() Liyu, Andrei
Next: Addendum to previous messgge: Possible bug in registerRecordDeviceDriver.pl Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Possible bug in registerRecordDeviceDriver.pl Kay-Uwe Kasemir
