On 2004.01.23 07:17, "Thompson, David H." wrote:
> I get the following error loading a library file on vxWorks/Epics
> 3.14.4:
> cd timingbin
> value = 0 = 0x0
> ld<timingLib.munch
> Undefined symbol: p (binding 1 type 0) <<<<<<<<<<<<<<<<<<<<<
Hi:
I had a similar problem caused by simplistic parsing in registerRecordDeviceDriver.pl.
In my case, a DBD line
driver(MyLameXYdevice)
was mistaken for a line ala
device(rec, link, dset, "name")
because after all "device" was part of the line.
That then created an empty "p" entry in the device list.
Similarly, anything with "registrar" will be taken as a registrar definition,
even if it's
# This is a comment about a registrar, but no registrar definition
The solution would be to make registerRecordDeviceDriver.pl
check more carefully. Take line 25: Instead of
if( /device/ )
it could be
if (/\A\s*device\s*\( )
Meanwhile, you'll have to check your DBDs to use "device" only for "device(.." etc.
-Kay
- Re: Possible bug in registerRecordDeviceDriver.pl Andrew Johnson
- Possible bug in registerRecordDeviceDriver.pl Thompson, David H.
epics thread Liyu, Andrei
<2004>
<2004>
