1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: registerRecordDeviceDriver Problem
To: "Kim, Kukhee" <[email protected]>
Cc: [email protected]
Date: Tue, 03 Feb 2004 09:07:41 -0600
I don't see anything wrong. Here is a suggestion about how to proceed.
Make the following change to your source
static void epicsShareAPI drvVmivme5565Registrar(void)
to
void drvVmivme5565Registrar(void)
Thus temporily make this external instead of static
Now comment out everything in your st.cmd file starting with
rfm_registerRecordDeviceDriver(pdbbase)
Now boot you IOC and then
sp drvVmivme5565Registrar
What happens?
Kim, Kukhee wrote:
Dear ALL;
I am trying to make vmivme5565 RFM(Reflective Memory) supports on R3.14.4.
Now, I almost finished driver layer but I have a problem on the registration
of iocsh commands.  The vxWorks target shell was stopped when I executed
“rfm_registerRecordDeviceDriver(pdbbase)” command.   I guess,  just one line
in my code
-"iocshRegister(&vmivme5565_initFuncDef,vmivme5565_initCallFunc);"  - is
involved with this problem.  Because, if I commented it out, the "rfm_
registerRecordDeviceDriver" command is working.  I am going to attach a part
of my code. Would you check what is making the problem?
/* Registrar vmivme5565_init command */ static const iocshArg vmivme5565_initArg0 = {"card", iocshArgInt}; static const iocshArg vmivme5565_initArg1 = {"sram", iocshArgInt}; static const iocshArg vmivme5565_initArg2 = {"regs", iocshArgInt}; static const iocshArg vmivme5565_initArg3 = {"level", iocshArgInt}; static const iocshArg vmivme5565_initArg4 = {"vector", iocshArgInt};
static const iocshArg * const vmivme5565_initArgs[5] = {
&vmivme5565_initArg0,
&vmivme5565_initArg1,
&vmivme5565_initArg2,
&vmivme5565_initArg3,
&vmivme5565_initArg4};
static const iocshFuncDef vmivme5565_initFuncDef = {"vmivme5565_init",
5,
vmivme5565_initArgs};
static void vmivme5565_initCallFunc(const iocshArgBuf *args)
vmivme5565_init((unsigned long)args[0].ival,
(unsigned long)args[1].ival,
(unsigned long)args[2].ival,
(unsigned char)args[3].ival,
(unsigned char)args[4].ival);
static const iocshArg vmivme5565_testIRQArg0 = {"seconds", iocshArgDouble};
static const iocshArg * const vmivme5565_testIRQArgs[1] = {
&vmivme5565_testIRQArg0 };
static const iocshFuncDef vmivme5565_testIRQDef = {"vmivme5565_testIRQ",
                                                    1,
                                                    vmivme5565_testIRQArgs};
static void vmivme5565_testIRQCallFunc(const iocshArgBuf *args)
    vmivme5565_testIRQ(args[0].dval);
    static int firstTime = TRUE;
    if(firstTime) {
        firstTime=FALSE;
/* !!!comment out this line!!! */
        iocshRegister(&vmivme5565_testIRQDef,vmivme5565_testIRQCallFunc);
epicsExportRegistrar(drvVmivme5565Registrar);
----------------- Kukhee Kim Instrument & Control, KSTAR Korea Basic Science Institute 52 Yeoeun-dong, Yusung-gu, Daejeon 305-333 Korea Email: [email protected] Tel: +82 42 870 1616 Fax: +82 42 870 1609 Cell: +82 17 513 4849
RE: registerRecordDeviceDriver Problem Kim, Kukhee
Prev: Device Support for Keithley 486 Thomas Hahn
Next: RE: registerRecordDeviceDriver Problem Kim, Kukhee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: registerRecordDeviceDriver Problem Kim, Kukhee
