Dear Marty;
I just figured out what is the problem. One of my VME module was broken.
So, it makes hanging the CPU when I touch any VME address space. The
registration procedure is OK. I bark up the wrong tree :-)
Thank you for your helps.
Kukhee Kim
Instrument & Control, KSTAR
Korea Basic Science Institute
52 Yeoeun-dong, Yusung-gu, Daejeon 305-333
Korea
Email: [email protected]
Tel: +82 42 870 1616 Fax: +82 42 870 1609 Cell: +82 17 513 4849
-----Original Message-----
Sent: Wednesday, February 04, 2004 12:08 AM
To: Kim, Kukhee
Cc: [email protected]
Subject: Re: registerRecordDeviceDriver Problem
I don't see anything wrong. Here is a suggestion about how to proceed.
Make the following change to your source
static void epicsShareAPI drvVmivme5565Registrar(void)
to
void drvVmivme5565Registrar(void)
Thus temporily make this external instead of static
Now comment out everything in your st.cmd file starting with
rfm_registerRecordDeviceDriver(pdbbase)
Now boot you IOC and then
sp drvVmivme5565Registrar
What happens?
Kim, Kukhee wrote:
> Dear ALL;
> I am trying to make vmivme5565 RFM(Reflective Memory) supports on
R3.14..4.
> Now, I almost finished driver layer but I have a problem on the
registration
> of iocsh commands. The vxWorks target shell was stopped when I executed
> "rfm_registerRecordDeviceDriver(pdbbase)" command. I guess, just one
line
> in my code
> -"iocshRegister(&vmivme5565_initFuncDef,vmivme5565_initCallFunc);" - is
> involved with this problem. Because, if I commented it out, the "rfm_
> registerRecordDeviceDriver" command is working. I am going to attach a
part
> of my code. Would you check what is making the problem?
> /* Registrar vmivme5565_init command */
> static const iocshArg vmivme5565_initArg0 = {"card", iocshArgInt};
> static const iocshArg vmivme5565_initArg1 = {"sram", iocshArgInt};
> static const iocshArg vmivme5565_initArg2 = {"regs", iocshArgInt};
> static const iocshArg vmivme5565_initArg3 = {"level", iocshArgInt};
> static const iocshArg vmivme5565_initArg4 = {"vector", iocshArgInt};
> static const iocshArg * const vmivme5565_initArgs[5] = {
> &vmivme5565_initArg0,
> &vmivme5565_initArg1,
> &vmivme5565_initArg2,
> &vmivme5565_initArg3,
> &vmivme5565_initArg4};
> static const iocshFuncDef vmivme5565_initFuncDef = {"vmivme5565_init",
> 5,
> vmivme5565_initArgs};
> static void vmivme5565_initCallFunc(const iocshArgBuf *args)
> vmivme5565_init((unsigned long)args[0].ival,
> (unsigned long)args[1].ival,
> (unsigned long)args[2].ival,
> (unsigned char)args[3].ival,
> (unsigned char)args[4].ival);
> static const iocshArg vmivme5565_testIRQArg0 = {"seconds",
iocshArgDouble};
> static const iocshArg * const vmivme5565_testIRQArgs[1] = {
> &vmivme5565_testIRQArg0 };
> static const iocshFuncDef vmivme5565_testIRQDef = {"vmivme5565_testIRQ",
> 1,
vmivme5565_testIRQArgs};
> static void vmivme5565_testIRQCallFunc(const iocshArgBuf *args)
> vmivme5565_testIRQ(args[0].dval);
> static int firstTime = TRUE;
> if(firstTime) {
> firstTime=FALSE;
> /* !!!comment out this line!!! */
> iocshRegister(&vmivme5565_testIRQDef,vmivme5565_testIRQCallFunc);
> epicsExportRegistrar(drvVmivme5565Registrar);
> Kukhee Kim
> Korea
- Re: registerRecordDeviceDriver Problem Marty Kraimer
ChannelArchiver and gcc 3.2.2 on linux Peter Groszkowski
<2004>
2025
Device Support for Keithley 486 Thomas Hahn
<2004>
2025
