1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Definitions of RELEASE_ variables
To: Chris Mayer <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 6 Feb 2004 09:48:28 +0100
Chris,
Probably someone answered that already in a private mail, but as I don't
see any answer on Tech-Talk:
These two definitions are generated by "make" in the configure directory
of your application. If make was working properly, they should be
contained in the file <TOP>/configure/O.<ARCH>/CONFIG_APP_INCLUDE which
is included by your app's makefiles.
After changing things in the configure directory it is important to run
"make" there before trying to rebuild the apps themselves.
If things seem to be messed up, try running "make clean" followed by
"make" (in one word: "make clean all") in the configure directory. This
should regenerate the stuff that your other makefiles include.
Hope this helps,
Ralph
>>>>> "Chris" == Chris Mayer <[email protected]> writes:
  >   Can someone point me to how and where  RELEASE_DBDFLAGS and
  > RELEASE_INCLUDES get defined within makeBaseApp under 3.14
  >   After moving an application from one directory to another I am having
  > problems recompiling. After some checks I found that both
  > RELEASE_DBDFLAGS and RELEASE_INCLUDES were undefined. I'm not quite sure
  > yet how I've messed up but when I checked the configure directory
  > although I can see where these variables are used I couldn't find where
  > they are defined.
  >     Many thanks
  >       Chris
Definitions of RELEASE_ variables Chris Mayer
Prev: A-B SLC 5/05 Ethernet Driver. Kiman Ha
Next: asynDriver Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Definitions of RELEASE_ variables Chris Mayer
Next: WINSOCK Error 10055 Steven . Banks
