The original code was from Triumf, Canada. I need to change the offset with BO_OFFSET in drvModtcp.c: #define WAGO #if defined(WAGO) unsigned short BO_OFFSET=0x200; #else unsigned short BO_OFFSET=0x0; #endif =============================================== int modtcpWrite(int index, int addr, unsigned short mask, unsigned short *pData) { PLC_ID pPlc; SOCKET_ID pSock; int i, error, ok; unsigned short outval, *pOut; pPlc = Plcs[index]; if (!pPlc->pSock2->tcpsFd) return -1; pOut = pPlc->memStart + addr + BO_OFFSET - 1; ================================================== /* set pFrom pointer to begin of EPICS local buffer or to VME slave memory (SDLC) */ if (pGr->readAddr < pPlc->memLength) pFrom = pPlc->memStart + pGr->readAddr + BO_OFFSET - 1; =================================================== Just to give you some ideas. I am going to clean this up after other higher priority jobs. May be then we could generate some useful diff's for you. Good luck. Ivan So NSLS, BNL
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
