1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: drvAscii ipacAddCarrier routine
To: [email protected]
Date: Tue, 17 Feb 2004 10:18:17 -0700
I'm using drvIpac 1.7 on an MV167 with EPICS 3.13.4. Since I'm using the GreenSpring IP-Octal card, extra memory needs to be allocated. In the startup file, the command
ipacAddCarrier &vipc616,"0xC000,0xA00000,512"
is executed. If there's nothing but the IP-Octal on the crate, then that works fine. But once many other modules are added to the crate, then a memory access error stops the boot at this point. The problem is that I don't know a rational method to choose the address parameters. So far I've just used trial and error. Does anyone have any guidance?
Re: drvAscii ipacAddCarrier routine Andrew Johnson
Prev: RE: CA question Jeff Hill
Next: Re: VDCT strips \ character from field definitions John Maclean
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: How is it that IOC process only 11000 records per second at A MD Duron 850MHz? Hunt Steven
Next: Re: drvAscii ipacAddCarrier routine Andrew Johnson
