On 2004.03.08 09:59, john sinclair wrote:
> Kay,
> Is this also true for FlexLogix I/O?
Don't know FlexLogix I/O, but I'm afraid
the EPICS driver for the ControlLogix 5000 PLC
is really specific to the ControlLogix 5000
and its CIP service codes 0x0A, 0x4C, 0x4D.
The ControlNet/EtherNet/IP specifications include
an "Object Library".
In there you find an "Identity" object.
Any EtherNet/IP decide implements that.
The EPICS driver for the Logix 5000 uses queries it
to get the serial number of the Logix 5000 ENET module.
There is a "Message Router" object:
We use that to get from the ENET module to the Logix 5000
controller (where the ladder logix runs).
When I contact the MessageRouter on FlexLogix I/O
the same way I contact the MessageRouter onthe Logix 5000
ENET module, I'm pretty sure the response will be:
"Invalid Path", because the path from the Logix 5000 ENET module
to the controller in slot 0 of the Logix 5000 backplane
simply doesn't exist on FlexLogix.
Then there are "Discrete Input Point", "Output Point",
"Analog Input Point" etc. objects:
Maybe you can use those to access I/O points
on any "EtherNet/IP" device.
But I was't getting anywhere with them for the
Logix 5000. And in order to read/write tags in
the Logix 5000 ladder logic, which is what I
ultimately wanted to do, I had to use the Logix-specific
service tags.
So talk about a device using "EtherNet/IP" and thus
being compatible is just like me handing you
the telephone number of my aunt in Germany:
Your telephone is certainly compatible with hers,
but I think the communication wouldn't go past a
> "Hello?"
< "Hallo?"
> "Do you speak English?"
< "Sprechen Sie Deutsch?"
> "Hello?"
< "Hallo?"
- click -
- Klick -
> John Sinclair
> On Monday 08 March 2004 11:13 am, Kay-Uwe Kasemir wrote:
> > On 2004.03.08 02:24, Kiman Ha wrote:
> > > Hello! Kay and Stephanie,
> > > Last Feb, I asked about AB SLC5/05 processor for Ethernet TCP/IP EPICS
> > > driver and support.
> > > The AB Comapny people said SLS5/05 PLC processor support EtherNet/IP.
> > Yes, it might support the common portion of the EtherNet/IP
> > protocol, the part that's documented at www.odva.org.
> > That will allow you to read the serial number of your SLC5/05's
> > ethernet interface.
> > In addition, you need the CIP service codes that are specific
> > to your PLC, the ones that allow you to read/write tags
> > or files or whatever the data of interest is called on the
> > respective architecture.
> > > I known your alread developed EtherNet/IP drivers and support for SNS
> > > project.
> > That EtherNet/IP driver package uses the CIP codes for the
> > AB ControlLogix 5000 series as described in
> > AB Publication 1756-RM005A-EN-E.
> > The latter publication also lists SCL commands,
> > but they are very different from the CIP service codes
> > for the ControlLogix series.
> > Control Logix uses CIP service codes
> > 0x4C : read data
> > 0x4D : write data
> > 0x0A : multi request
> > and all those adress string tags on the Logix5000.
> > As far as I know, the SCL5 doesn't have string tags
> > but uses file/element/subelement addressing.
> > So I'm afraid those AB people who talked to you can
> > recite "EtherIP" from some SLC5 brochure but don't
> > really understand the protocol.
> > This means that the ether-ip driver for the ControlLogix 5000 won't
> > talk to the SLC5, and making it talk to the SLC5 would be a major deal,
> > close to starting from scratch.
> John Sinclair
- EtherNet/IP for AB SLC5/05 PLC. Kiman Ha
- Re: EtherNet/IP for AB SLC5/05 PLC. Kay-Uwe Kasemir
- Re: EtherNet/IP for AB SLC5/05 PLC. john sinclair
RE: [Fwd: LabView/EPICS] Leng, Yongbin
RE: [Fwd: LabView/EPICS] Liyu, Andrei
<2004>
VMIC 2510B driver and device support Kristi Luchini
<2004>
