1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPU modules)
To: Kate Feng <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 24 Mar 2004 12:58:08 -0600
Kate Feng wrote:
> Please do not forget the system controller is in between the CPU and the
> VME slave.
You have either your nomenclature or your understanding of the architecture confused. The Universe-2 is between the CPU and the VME slave, but as I explained it can completely decouple the cycles on the two busses in some cases, and in others (such as VMEbus IACK cycles) there is no equivalent PCIbus cycle going on at all.
> How can the CPU see the DTACK asserted by the slave if the system
> controller is holding it up until the right time ?
The CPU doesn't see DTACK, the Universe-2 chip does, and it doesn't go through the system controller (go back and read my last message again, where I say CPU I really mean the PowerPC processor chip via its PCI host bridge). In the case of a Read cycle the Universe-2 will read the data off the VMEbus and pass it back to the CPU and finish the pending PCIbus read cycle. However for a posted write cycle there is no reason to delay the CPU until the write completes, as it may be able to execute tens or even hundreds of instructions between performing the PCIbus write cycle and the VMEbus cycle completing.
The Universe-2 chip is not a simple VME signal interface like I suspect the Motorola VMEchip device was; there really is a lot going on under the hood, and it only couples the two busses together (i.e. delays its response on one while it's waiting for a related response on the other) if they really need to be coupled. That generally only occurs when the CPU does a read from a VMEbus address, or another VMEbus master does a read of memory on this card.
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night.  That was really cool. - Caro
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules) Kate Feng
mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Kate Feng
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Andrew Johnson
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules) Kate Feng
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules) Andrew Johnson
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPU modules) Kate Feng
Prev: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPU modules) Kate Feng
Next: 3.14-compatible synApps Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules) Kate Feng
