1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules)
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 26 Mar 2004 10:38:10 -0500
Hi Andrew,
Thank you very much for your patience and explaination.  Please
excuse me if  I miss something or misunderstand something
because  my  main focus  is on my own assignment.
Andrew Johnson wrote:
>  In the case of a Read cycle the Universe-2 will read the data
> off the VMEbus and pass it back to the CPU and finish the pending PCIbus
> read cycle.  However for a posted write cycle there is no reason to delay
> the CPU until the write completes, as it may be able to execute tens or
> even hundreds of instructions between performing the PCIbus write cycle
> and the VMEbus cycle completing.
I think you meant that the address pipelining on the UniverseII chip is
done via the posted write, which  makes more sense for me now.
However, I just did  a test and found out that one can disable the
posted write on the UniverseII running RTEMS-mvme5500.  With a
coupled cycle (posted write disable),  the VME bus master only
receives DTACK  when the data  transition is complete on the PCI bus.
This means that the VMEbus is unavailable to other masters while
the  PCI bus transaction is executed.
I agree with you  that one should enable the posted write by default.
However, it could be disabled, which means the address
pipelining on the  UniverseII could be disabled as well on the Mvme5500.
I thought the origianl issue is "to disable the  address pipelinig".
It  looks like you have a reason to disable the posted write
for the NI VME-MXI-1.   The trad off is to sacrifice the bandwidth
of the VME bus.  However, I do not know if  the decrease is
significant for your application.   I hope this helps.
Kate
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules) Kate Feng
et_wish mon problem Lei Ge
mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Kate Feng
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Andrew Johnson
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules) Kate Feng
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules) Andrew Johnson
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPU modules) Kate Feng
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPU modules) Andrew Johnson
Prev: RE: some of my scan tasks are not being processed because of long delays. Sibley III, Coles
Next: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules) Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPU modules) Andrew Johnson
