1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Buffer problems
Cc: [email protected]
Date: Wed, 24 Mar 2004 16:20:45 -0600
Mark Rivers wrote:
At least 2 IOCs at Brookhaven, on the same subnet, just got lots of the following errors:
iocx17b2> ../online_notify.c: CA beacon (send to "130.199.193.255:5065")
error was "S_errno_ENOBUFS"
So this looks OK?  Is there something else I should check?  Clearly
something is going on on the network there that is causing these
problems.
There are two different kinds of network buffers in vxWorks that can run out. In Tornado 2.x mbufShow() is a synonym for netStackDataPoolShow() which shows the buffers used by the IP stack for data packets. There is another command netStackSysPoolShow() which is shows the state of the system buffer pool - these buffers are used for the ARP cache, routing tables and other system storage associated with the network.
However in the above case you might find there's nothing wrong with these buffers either. I'm not quite sure what causes ENOBUFS errors when sending CA beacons; I have seen similar errors on IOCs here that have never run out of DataPool or SysPool buffers, and I don't yet know what they're complaining about (any ideas Jeff?). They do appear to be benign though, if my memory is correct - the loss of a beacon can cause some unnecessary CA searches to occur, but nothing should break.
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night.  That was really cool. - Caro
RE: Buffer problems Jeff Hill
Buffer problems Mark Rivers
Prev: Buffer problems Mark Rivers
Next: RE: Buffer problems Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Buffer problems Jeff Hill
