1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Buffer problems
To: "Andrew Johnson" <[email protected]>
Cc: <[email protected]>
Date: Wed, 24 Mar 2004 16:30:36 -0600
Andrew,
>  I'm not quite sure what causes ENOBUFS errors when
> sending CA beacons; I have seen similar errors on IOCs here that have
> never run out of DataPool or SysPool buffers, and I don't yet
> know what they're complaining about (any ideas Jeff?).  They do appear
> to be benign though, if my memory is correct - the loss of a beacon
can cause some
> unnecessary CA searches to occur, but nothing should break.
Things are not benign for us, though the CA error messages may just be
symptomatic of deeper problems.  We have lost NFS and CA connectivity,
and we have to reboot.  It runs for a while, and then it happens again.
I suspect there is a machine on the network there that is infected with
some virus, and periodically blasting each machine on the network.
Disconnecting the beamline switch from the network has fixed the
problem, but of course that means I can't diagnose it from here at
Argonne.
Re: Buffer problems john sinclair
Re: Buffer problems Tim Mooney
Prev: Re: Buffer problems Andrew Johnson
Next: Re: Buffer problems john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Buffer problems Jeff Hill
