Remark: The substittutions $HOPR and $LOPR are used in both files, but in the .substitution files it is forgotten for the second file, test1.template. I am unable to replicate your results using EPICS R3.13.9, R3.13.10 or R3.14.6. These are my source files: :::::::::::::: test.substitutions :::::::::::::: file test.template { { NAME="X", HOPR="9", LOPR="1"} } file test1.template { { NAME="Y" } } :::::::::::::: test.template :::::::::::::: record(calc,"$(NAME):rdbk") { field(DESC,"calculation") field(SCAN,".5 second") field(CALC,"A") field(INPA,"$(NAME):rd .PP.NMS") field(HOPR,"$(HOPR)") field(LOPR,"$(LOPR)") } :::::::::::::: test1.template :::::::::::::: record(ai,"$(NAME):rd") { field(DESC,"position readback") field(HOPR,"$(HOPR)") field(LOPR,"$(LOPR)") } These are the messages I get when expanding that substitutions file on the host using dbLoadTemplate: Inflating database from test.substitutions <string>: HOPR referenced but undefined macExpandString failed <string>: LOPR referenced but undefined macExpandString failed Installing database ../../../db/test.db rm test.t.db.raw Unfortunately it does install the test.db file, when it should have aborted the make because of the errors - this is not a bug in dbLoadTemplates, it's a problem with the EPICS build system. However, it did generate warning messages, and the file it actually installed looks like this: record(calc,"X:rdbk") { field(DESC, "calculation") field(SCAN, ".5 second") field(CALC, "A") field(INPA, "X:rd .PP.NMS") field(HOPR, "9") field(LOPR, "1")} record(ai,"Y:rd") { field(DESC, "position readback") field(HOPR, "$(HOPR)") field(LOPR, "$(LOPR)")} i.e. it did not keep the old values for $(HOPR) and $(LOPR), it just didn't replace the macros. If I use dbLoadRecords on the IOC instead, I get these error messages: iocexample> dbLoadTemplate "test.substitutions" IocLogClient: EPICS environment variable "EPICS_IOC_LOG_INET" undefined iocLogClient: logging disabled macExpandString failed Cannot set field HOPR to $(HOPR) macExpandString failed Cannot set field LOPR to $(LOPR) filename="../macCore.c" line number=709 <string>: HOPR referenced but undefined Y:rd.HOPR Has unexpanded macro filename="../macCore.c" line number=709 <string>: LOPR referenced but undefined Y:rd.LOPR Has unexpanded macro The database after loading looks like this: iocexample> dbDumpRecord pdbbase, 0, 0 record(ai,"Y:rd") { field(DESC,"position readback") field(DTYP,"Soft Channel") } record(calc,"X:rdbk") { field(DESC,"calculation") field(SCAN,".5 second") field(CALC,"A") field(INPA,"X:rd PP NMS") field(HOPR,"9") field(LOPR,"1") } value = 0 = 0x0 i.e. no value is given to Y:rd.HOPR and Y:rd.LOPR, they remain at their default values. On R3.14.6, the IOC expansion is even more verbose with error messages: dbLoadTemplate("test.substitutions") Error Last token ")" input line: field(HOPR,"$(HOPR)") in: path "." file test1.template line 3 The only way we can replicate your results here is by using msi to do the macro expansion on the host, which gives: phoebus% msi -S test.substitutions record(calc,"X:rdbk") { field(DESC,"calculation") field(SCAN,".5 second") field(CALC,"A") field(INPA,"X:rd .PP.NMS") field(HOPR,"9") field(LOPR,"1") } record(ai,"Y:rd") { field(DESC,"position readback") field(HOPR,"9") field(LOPR,"1") } We will therefor be releasing a new version of MSI which behaves like the old dbLoadTemplate program and leaves the unexpanded $(HOPR) and $(LOPR) variables in the output. Note that the rules for how templates are expanded are found in the IOC application's <top>/config/RULES.Db file. We assume that your RULES.Db has been modified to use msi instead of dbLoadTemplate. We are also leaning towards implementing Andreas Luedeke's suggestion of being able to put default values for particular macros inside the template file. If you wish to persue your idea of including defaults in the substitutions file pattern line, you'll have to write your own tool to do that (or modify one of the existing EPICS programs). - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
