Hi Andrew,
as I posted last week, there is a bug in dbAccess.c that can crash the
ioc when DTYP is read via CA. The bug is still present in the newly
released 3.14.6. I think it has been there from the very beginning of
EPICS. As I tested today, a Linux ioc also crashes (segmentation fault).
That there were no crashes on 68k processors seems to be coincidental
(or just luck).
The problem is that for records without device support (calc, etc.) the
dbDeviceMenu pointer is NULL. When it is dereferenced in
get_enum_strs(), no check is done and pdbDeviceMenu->nChoice and
pdbDeviceMenu->papChoice have arbitrary values.
Since I consider crashing an ioc with a read a major bug, I would be
pleased to see this fixed in at least the latest version.
Dirk
Andrew Johnson wrote:
EPICS Base release 3.14.6 has been available for download since last
Friday, but we didn't have the IOC Application Developers Guide in place
until today, hence the delayed release announcement. This version of
Base contains many minor enhancements and bug fixes, especially to the
Channel Access client library, which is significantly more robust and
reliable than R3.14.5 was.
There is a known problem with compiling this release against Tornado
2.2, although the failure happens when building a test program after
everything required for normal use has been compiled, so this is
benign. There may also be an issue when building some extensions using
the solaris-sparc-gnu architecture, but that's unconfirmed at present
(we hope Janet gets better soon).
Thanks to all the core development team.
- Andrew
Dirk Zimoch wrote:
Hi all,
at least on all EPICS releases 3.13.2 to 3.13.9, is a bug that causes crashes on PPC iocs. (I have not seen a 68k crash here.)
Bug:
When reading the DTYP field of "pure soft records" such as calc via CA, the CA_client task crashes and leaves the ioc in a state where no further access via CA is possible.
data access
Exception current instruction address: 0x01705f54
Machine Status Register: 0x0000b030
Data Access Register: 0xf0f0f0f0
Condition Register: 0x28000040
Data storage interrupt Register: 0x40000000
Task: 0x17c31f0 "CA_client"
tt
17807c vxTaskEntry +60 : camsgtask ()
1727a44 camsgtask +2e4: camessage ()
172a7f0 camessage +120: read_action ()
17286bc read_action +e8 : read_reply ()
17284b4 read_reply +144: db_get_field ()
171f838 .L198 +40 : dbGetField ()
1707650 dbGetField +164: dbGet ()
1707760 dbGet +cc : getOptions ()
17065d8 getOptions +208: get_enum_strs ()
Fix:
*** base/src/db/dbAccess.c.orig Thu Jun 3 18:04:26 2004
--- base/src/db/dbAccess.c Thu Jun 3 18:10:33 2004
*** 129,134 ****
--- 129,138 ----
goto choice_common;
case DBF_DEVICE:
pdbDeviceMenu = (dbDeviceMenu *)pdbFldDes->ftPvt;
+ if (pdbDeviceMenu == NULL) {
+ no_str = 0;
+ goto choice_common;
no_str = pdbDeviceMenu->nChoice;
papChoice = pdbDeviceMenu->papChoice;
goto choice_common;
After this fix, calc records and the like report DTYP as 0.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax +41 56 310 4413
- Re: EPICS Base Release 3.14.6 Marty Kraimer
- EPICS Base Release 3.14.6 Andrew Johnson
RE: Question on transition modules Luchini, Kristi
<2004>
<2004>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
