1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: virtual circuit disconnect
To: "Zheng Lifang" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 28 Jun 2004 14:52:28 +0200
Hi Lifang,
you shouldn't have to set the EPICS_CA_ADDR_LIST in that case, as using
a broadcast on the local network is the default behaviour when a CA
clients wants to connect.
Do you get the same results if you don't set the variable - neither on
the PC nor on the IOC?
Ralph
>>>>> "Zheng" == Zheng Lifang <[email protected]> writes:
  > Hi All,
  > We set 192.168.26.n as our control subnet. A PC/Redhat9.0 (with its IP 192.168.26.2) runs edm, and its netmask is set to ffffff00 . The IOC IP address is set to 192.168.26.11:ffffff00 in the boot parameter.
  > The IOC downloads vxWorks and EPICS normally from PC/Redhat. In st.cmd there is putenv("EPICS_CA_ADDR_LIST=192.168.26.255") before iocInit. Also in PC/Linux I set EPICS_CA_ADDR_LIST=192.168.26.255 in .bash_profile .
  > But sometime edm can't connect to IOC, and displays the following messages:
  > CA.Client.Exception..........................
  >   Warning: "Virtual circuit disconnect"
  >   Context: "192.168.26.11:5064"
  >   Source File: ../cac.cpp line 1147
  >   Current Time: Mon Jun 28 2004 16:37:11.282870000
  > Where do I set incorrectly or should pay attention more?
  > Regards,
  > Lifang
RE: virtual circuit disconnect Jeff Hill
caRepeater working practices Simon Rees
virtual circuit disconnect Zheng Lifang
Prev: virtual circuit disconnect Zheng Lifang
Next: RE: virtual circuit disconnect Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
