1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: virtual circuit disconnect
To: "'Ralph Lange'" <[email protected]>, "'Zheng Lifang'" <[email protected]>
Cc: "'EPICS Tech-Talk'" <[email protected]>
Date: Mon, 28 Jun 2004 09:14:36 -0600
Hello Lifang,
I concur with what Ralph has already said and would like to add some further
comments.
>   > CA.Client.Exception..........................
>   >   Warning: "Virtual circuit disconnect"
>   >   Context: "192.168.26.11:5064"
>   >   Source File: ../cac.cpp line 1147
>   >   Current Time: Mon Jun 28 2004 16:37:11.282870000
Of course, this type of message is normal if EDM looses network connectivity
with the IOC. Otherwise, what version of EPICS are you using? I seem to
recall that there were some problems with erroneous CA client library
disconnects in the very earliest beta releases of EPICS R3.14.
Jeff
> -----Original Message-----
> From: Ralph Lange [mailto:[email protected]]
> Sent: Monday, June 28, 2004 6:52 AM
> To: Zheng Lifang
> Cc: EPICS Tech-Talk
> Subject: Re: virtual circuit disconnect
> Hi Lifang,
> you shouldn't have to set the EPICS_CA_ADDR_LIST in that case, as using
> a broadcast on the local network is the default behaviour when a CA
> clients wants to connect.
> Do you get the same results if you don't set the variable - neither on
> the PC nor on the IOC?
> Regards,
> Ralph
> >>>>> "Zheng" == Zheng Lifang <[email protected]> writes:
>   > Hi All,
>   > We set 192.168.26.n as our control subnet. A PC/Redhat9.0 (with its
> IP 192.168.26.2) runs edm, and its netmask is set to ffffff00 . The IOC
> IP address is set to 192.168.26.11:ffffff00 in the boot parameter.
>   > The IOC downloads vxWorks and EPICS normally from PC/Redhat. In
> st.cmd there is putenv("EPICS_CA_ADDR_LIST=192.168.26.255") before
> iocInit. Also in PC/Linux I set EPICS_CA_ADDR_LIST=192.168.26.255
> in .bash_profile .
>   > But sometime edm can't connect to IOC, and displays the following
> messages:
>   > Where do I set incorrectly or should pay attention more?
>   > Regards,
>   > Lifang
Re: virtual circuit disconnect Ralph Lange
Prev: Re: virtual circuit disconnect Ralph Lange
Next: caRepeater working practices Simon Rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
