1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: RTEMS-mvme5500 BSP available
To: "'Joel Sherrill <[email protected]> '" <[email protected]>
Cc: "''Till Straumann ' '" <[email protected]>, "'''[email protected]' ' '" <[email protected]>, "'''[email protected]' ' '" <[email protected]>
Date: Thu, 14 Oct 2004 15:52:55 -0400
Hi all,
Finally, we got official approval from DOE to release the
RTEMS-mvme5500 BSP under EPICS open source.  Before the BSP
is officially merged to the RTEMS release,  the source code
can be downloaded from :
http://www.nsls.bnl.gov/organization/UserScience/Detectors/Software
Joel Sherrill wrote :
> Feng, Shuchen wrote:
>> May I know what is the requirement of the official submission ?
> Source code is the first and most obvious one.
> The second is permission.  This involves you transmitting the
> code to the RTEMS Project via email, ftp to incoming, etc..
> The source code must have appropriate licensing and
> redistribution requirements.  Given that you are submitting
> a BSP, the license should be standard RTEMS -- GPL with
> exception.
As per discussion off-line regarding the license,  Joel had
accepted the EPICS license consdering the fact that it is
compatible with the RTEMS one. Many thanks to Joel's
consideration.
> The third is practical.  I don't want to merge any code
> before you think it is ready.
I think it is ready.  Presently, there is no known bug
based on our application.  I think I even fixed the URL
wrapped  problem from the original message below.
Looking forwards to feedback.
Kate
> -----Original Message-----
> From: Joel Sherrill <[email protected]>
> To: Till Straumann
> Cc: Feng, Shuchen; '[email protected]'; '[email protected]'
> Sent: 9/20/2004 5:42 PM
> Subject: Re: RTEMS-mvme5500 BSP available
>>>Hello,
>>>The source code  for the  RTEMS-mvme5500 BSP  is
>>>available  for evaluation upon request  to [email protected]
>>>before it's  in the RTEMS source tree.
>>>Other  related document can be found at
http://www.nsls.bnl.gov/organization/UserScience/Detectors/Software/Defa
> ult.
>>I get an infamous Http/404 (page not found) error when trying
>>to access this page :-(
> The URL wrapped .. add "htm" after the "." at the end.
> THis looks like a pre-submission test snapshot again. :(
> Still waiting.. hoping... :)
> --joel
>>-- T.
>>>htm
>>>Regards,
>>>Kate
Joel Sherrill, Ph.D.             Director of Research & Development
[email protected]                 On-Line Applications Research
Ask me about RTEMS: a free RTOS  Huntsville AL 35805
    Support Available             (256) 722-9985
Prev: RE: How much is EPICS worth? Dalesio, Leo
Next: VME Address Modifiers in mv2400 Nick Rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: RTEMS-mvme5500 BSP available Joel Sherrill <[email protected]>
Next: caget caput Michael O'Farrell
