1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VME Address Modifiers in mv2400
To: [email protected]
Date: Thu, 14 Oct 2004 12:19:04 -1000 (HST)
I just had a problem swapping a system from a Heurikon board to a PPC
mvme2400.
It turned out that I had a VME board (VMIC4514) that responded to either
supervisory or user A16 I/O, but couldn't be set to respond to both. It
was set to respond to supervisory mode I/O because that is what I thought
all VxWorks BSP's used. However, this worked with the Heurikon
board, but didn't work with the PPC.
Has anyone seen this before. Does anyone have a hint as to the bit of the
Motorola BSP I have to change to make it use supervisory VME access?
I apologise that this is really a VxWorks question, but I often find the
tech-talk list a lower bandwith option with equally good results.
Cheers,
Nick Rees
Head of Software and Computing Services
Joint Astronomy Centre                   Ph:         +1 (808) 961-3756
660 N. Aohoku Place                      Fax:        +1 (808) 961-6516
Hilo, HI.  96720                         Email: [email protected]
Re: VME Address Modifiers in mv2400 Ronald L. Sluiter
Prev: RE: RTEMS-mvme5500 BSP available Feng, Shuchen
Next: list of *all* EPICS records Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM timeout? Mathias Steiner
Next: Re: VME Address Modifiers in mv2400 Ronald L. Sluiter
