1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Index of highest value
Cc: "Lawrence T. Hoff" <[email protected]>, [email protected]
Date: Mon, 20 Dec 2004 14:22:09 -0600
Tim Mooney wrote:
I don't have any suggestion for doing this with only the records in base, but you could do everything you've described with one transform record, which I'll call 'T'. Here are the field definitions:
T.A ... T.L are the goodness factors
T.CMTA ... T.CMTL are per-foil descriptions/comments, if needed
T.CLCM is 'max(a,b,c,d,e,f,g,h,i,j,k,l)'
T.CLCN is 'a==m?1:b==m?2:c==m?3:d==m?4:e==m?5:0'
T.CLCO is 'f==m?6:g==m?7:h==m?8:i==m?9:j==m?10:0'
T.CLCP is '(k==m?11:l==m?12:n+o)-1'
After the record processes:
T.M is the max goodness factor
T.P is the index of the best foil
T.OUTP is the PV to which you want to write the foil index.
Oops. I ignored the possibility that two foils might have the same goodness factor, which is also the highest goodness factor. In this case, we could just take the first:
T.CLCO is 'n?0:f==m?6:g==m?7:h==m?8:i==m?9:j==m?10:0'
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab
Index of highest value Lawrence T. Hoff
Re: Index of highest value Tim Mooney
Prev: Re: database conversion john sinclair
Next: Re: Micos Motor Support query. David Maden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Index of highest value Tim Mooney
Next: EPICS VLINAC demo on MacOS X (darwin) Stephen Lewis
