1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Micos Motor Support query.
To: "Kurt A. Goetze" <[email protected]>
Date: Mon, 20 Dec 2004 21:49:05 +0100
Hi Kurt,
Yes, I had seen that. From what I can glean from Micos' web site, I suspect that it is not a "Venus-2" device. If it is, it would be great. I'll check with Micos and get back to you.
David
Kurt A. Goetze wrote:
David Maden wrote:
We have just received a rotation table from Micos GmbH for a trial period. It has an RS-232-C interface talking what they call "Venus-2 protocol".
Simple command/response communication via Dirk Zimok's stream driver works fine and we can get it to move and report its position. Has anyone in the EPICS community perhaps tackled a more thorough integration, in particular, into the APS motor record package?
Thanks in advance for any tips.
David
David,
There is motor record device support for the Micos MoCo series DC motor controllers
in synApps 5.0 and above. I can send you the source code for earlier versions if needed.
http://www.aps.anl.gov/aod/bcda/synApps
Kurt Goetze
ANL/APS Beamline Controls
ph: 630-252-7959
em: [email protected]
Micos Motor Support query. David Maden
Re: Micos Motor Support query. Kurt A. Goetze
Prev: Re: Index of highest value Tim Mooney
Next: Porting db file generation from 3.13 to 3.14 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Micos Motor Support query. Kurt A. Goetze
Next: asynDriver release R4-1 Marty Kraimer
