Mark,
I ran regression tests using MS visual C++ version 7.1 (from 2003). If it's
not terribly difficult to use a newer version then that would be my
preferred temporary solution. Of course, the best long term solution will be
to release win32-x86 as a binary install. I suppose that another option for
you would be to use the Borland compiler, or to add CONFIG changes so that
the cygwin compiler can be used to compile the WIN32 EPICS OSI without using
the cygwin EPICS OSI interfaces (which last time I checked didn't work
well).
The code in question is a last gasp attempt to print a decent message when
an unexpected exception occurs in a thread (and it isn't caught at a higher
level).
Jeff
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Tuesday, January 04, 2005 5:55 PM
> To: [email protected]
> Subject: Problem building 3.14.7 on win32-x86
> Folks,
> I am trying to build EPICS 3.14.7 on Windows (win32-x86). I am using
> Visual C++ 6.0. I get the following error when building
> libCom/epicsThread.cpp.
> cl /nologo /GX /GR -c /D__STDC__=0 /Ox /W3 /MD
> -I. -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I
> ...\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc
> -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libC
> om\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates
> -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I.
> ..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error
> -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\
> \freeList -I..\\..\\..\\src\\libCom\\gpHash
> -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib
> -I..\
> \..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi
> -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\t
> imer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32
> -I..\\..\\..\\include /Tp ..\\..\\..\\src
> \\libCom\\osi\\epicsThread.cpp
> epicsThread.cpp
> ...\..\..\src\libCom\osi\epicsThread.cpp(80) : error C2039: 'unexpected'
> : is not a member of 'std'
> ...\..\..\src\libCom\osi\epicsThread.cpp(96) : error C2039: 'unexpected'
> make[3]: *** [epicsThread.obj] Error 2
> make[3]: Leaving directory
> `/cygdrive/h/epics/base-3.14.7/src/libCom/O.win32-x86'
> make[2]: *** [install.win32-x86] Error 2
> make[2]: Leaving directory `/cygdrive/h/epics/base-3.14.7/src/libCom'
> make[1]: *** [libCom.install] Error 2
> make[1]: Leaving directory `/cygdrive/h/epics/base-3.14.7/src'
> make: *** [src.install] Error 2
> Is this a known problem, and is there a fix?
> Thanks,
> Mark
- Problem building 3.14.7 on win32-x86 Mark Rivers
Web service interfaces for EPICS Bill St. Arnaud
<2005>
Re: sysAtReboot Andrew Johnson
<2005>
