On Monday 11 April 2005 16:56, Liyu, Andrei wrote:
> If I am not mistaken there are not couple features in current CA
> function interface.
> I can suppose that when you came to multithread CA you added
> get_current_context and attach functions. But there is not similar
> mechanism for ca_context_destoy.
> So I open first thread, create CA context, create first CA
> channel. Then I open second thread, attach to current CA context, create
> second CA channel. ... Then I decide to close first CA channel and
> close context (???!!!). What is behavior CA library? I suppose second CA
> channel will be closed without normal procedure of closing second
> channel + its monitor?
> But I don't like to close second channel and CA context! Then I
> should check is that channel latest? I couldn't find suitable function
> in CA function API. Maybe get_current_context has something. But it is
> very deep.
> I have once way - hold tracks of my CA channels (minimum is
> global counter). Usually it could be done. But if program is mixture of
> different libraries and each library comes to CA library then it becomes
> impossible.
Hi Andrei,
I asked Jeff a similar thing a while ago. Specifically, I asked for a feature
ca_detach_context that would be the opposite of ca_attach_context (and could
also be used to detach the thread that created the context in the first
place[*]). He seemed to be open to the suggestion but I don't know if it is
planned to be included in the next epics release.
Ben
[*] ca_create_context in fact does two separate things: It creates a context
and then attaches the calling thread to it; whereas ca_destroy_context first
detaches context from the caling thread, then destroyes the context.
- CA; ca_context_destoy and CA channels Liyu, Andrei
Re: EPICS Web Server Problems Andrew Johnson
RE: CA; ca_context_destoy and CA channels Jeff Hill
<2005>
<2005>
