How about driving some of them with fanout records? Only one scan per fanout then.Or pointing CPP input links back to fields ... Or using the Event scan mechanism (together with an eventRecord) for groups of records that belong together... In general, the different stack sizes for EPICS base tasks are hardcoded (see <BASE>/src/libCom/osi/os/<OS>/osdThread.c). There is the possibility to switch completely to using the OS's default stack size (by setting OSITHREAD_USE_DEFAULT_STACK = YES when compiling EPICS base), but you would have to increase the default stack size on your target to make it large enough, which then would be used for *all* tasks, not just the "big" ones. I don't know if your system could live with such a waste of memory. Reorganizing your database in one of the mentioned ways is probably the most slim, elegant, and advisable solution. Ralph
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
