1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: 64-bit EPICS anyone?
To: Steven Hartman <[email protected]>
Cc: [email protected], EPICS tech-talk <[email protected]>
Date: Mon, 17 Oct 2005 18:04:06 -0400
On Mon, 2005-10-17 at 17:28 -0400, Steven Hartman wrote:
> On Sat, 15 Oct 2005, Ernest L. Williams Jr. wrote:
> > So EPICS BASE is really running in 64-bit mode, wow that was easy.
> > I hope something is not broken at run time.
> I played with epics base on 64-bit sparc (Solaris) a number of years ago
> (but never bothered to put it into widespread use).  As far as I could
> tell, everything with base was fine. I do not know about various
> extensions, though.
> The big caveat is to avoid mixing 32- and 64-bit libraries/applications.
> Your approach of a separate HOST_ARCH (and hence installation directories)
> with linux-x86_64 is likely necessary.  Depending upon how various
> distributions have configured gcc defaults, it may also be desirable to
> explicitly set the compiler flags (-m32 for linux-x86 and -m64 for
> linux-x86_64) so you don't inadvertently get a mix within an install
> directory depending upon the build host.
We are starting with 64-bit only mode to see how far we can get. :)
I am having a few problems with some of the (openmotif-based) extensions
at run-time but are working through the problems.
SNS Control Systems Group
ORNL
Re: 64-bit EPICS anyone? Brian McAllister
64-bit EPICS anyone? Ernest L. Williams Jr.
Re: 64-bit EPICS anyone? Zhijian Yin (ZY)
Re: 64-bit EPICS anyone? Ernest L. Williams Jr.
Re: 64-bit EPICS anyone? Steven Hartman
Prev: Re: 64-bit EPICS anyone? Steven Hartman
Next: Base3.14.7 compile under Intel Xscale processor Kiman Ha
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: 64-bit EPICS anyone? Brian McAllister
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
