Kenneth Evans, Jr. wrote: I have converted Jprobe to JCA 2.1 but it has not been committed. The reason is that it is becoming increasingly difficult to maintain Java packages as extensions in the EPICS build system, especially when they require more and more extra packages to build. They are probably best distributed another way. Thank you very much for providing this valuable program. I'm glad to inform that Jprobe 2.0.0.0 is now running on my Macintosh PowerBook G4 running MacOSX 10.3.9. Here is a list of versions of components, I use. Jprobe 2.0.0. JCA 2.1.6 CAJ 1.0.4 concurrent-1.3.1 java version "1.4.2_09" (Java SDK come with MacOSX)
http://jca.cosylab.com/apidocs/gov/aps/jca/JCALibrary.html#CHANNEL_ACCESS_JAVA says, we can set up the following properties for CHANNEL_ACCESS_JAVA context. com.cosylab.epics.caj.CAJContext.addr_list com.cosylab.epics.caj.CAJContext.auto_addr_list com.cosylab.epics.caj.CAJContext.connection_timeout com.cosylab.epics.caj.CAJContext.beacon_period com.cosylab.epics.caj.CAJContext.repeater_port com.cosylab.epics.caj.CAJContext.server_port com.cosylab.epics.caj.CAJContext.max_array_bytes com.cosylab.epics.caj.impl.reactor.lf.LeaderFollowersThreadPool.thread_pool_size However, I needed to use them with: com.cosylab.epics.caj.CAJContext.addressList com.cosylab.epics.caj.CAJContext.autoAddressList com.cosylab.epics.caj.CAJContext.connectionTimeout com.cosylab.epics.caj.CAJContext.beaconPeriod com.cosylab.epics.caj.CAJContext.repeaterPort com.cosylab.epics.caj.CAJContext.serverPort com.cosylab.epics.caj.CAJContext.maxArrayBytes com.cosylab.epics.caj.impl.reactor.lf.LeaderFollowersThreadPool.thread_pool_siz\ e to initialize a context property.
Thanks, Noboru Yamamoto EPICS group/KEKB control group KEK, JAPAN
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
