If your project allows for it, the smartest laid-back approach would be waiting for 3.14.8, which should be released within the next days (you can check the core-talk archive for latest information on the progress). Probably your problems will not appear using that version. If you want to help or if you're in a hurry, start with the nightly CVS snapshot, which should already be pretty close to the final 3.14.8 release. If in that case your problems persists, it would be really nice to include a fix into 3.14.8 before it is published. Thanks for your help! Ralph [email protected] wrote: I've been trying to build the EPICS 3.14.7 Base on a i586-suse-linux system using gcc 4.0.2, GNU Make 3.80, and Perl 5.8.7. After after many hurdles I've finally hit a brick wall.
ANJ, 02 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
