1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Base 3.14.7 build error on SUSE machine
To: [email protected]
Date: Fri, 4 Nov 2005 12:03:15 +0100
I've been trying to build the EPICS 3.14.7 Base on a i586-suse-linux system
using gcc 4.0.2, GNU Make 3.80, and Perl 5.8.7. After after many hurdles I've
finally hit a brick wall.
I followed the linked Wiki build instructions
(http://www.aps.anl.gov/epics/wiki/index.php/HowToPC104) and was confronted
with an error in which lcurses would not be found. After consulting a web fix,
this was fixed by changing lcurses to lncurses in
base-3.14.7/configure/os/CONFIG.Common.linux-x86. Unfortunately, due to lack of
foresight, I've lost the website URL for this fix, but it seemed to solve the
problem nicely.
When I gave the make command I then received errors of the following type:
./../../../src/cas/generic/casdef.h:513: error: ISO C++ forbids declaration of
'casPVI' with no type
../../../../src/cas/generic/casdef.h:513: error: expected ';' before '*' token
This time I consulted the Mantis bug database and found a patch for this problem
(http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=0000216). The patch
involved adding forward declarations of several class types to several C++
header files.
Although the patch got rid of the error messages above, I am now getting the
following error messages when I try to build:
../../../../include/gddUtils.h:85: warning: ?class gddDestructor? has
virtual functions but non-virtual destructor
../../../../src/cas/generic/casMonitor.h:42: warning: ?class
casMonitorCallbackInterface? has virtual functions but non-virtual destructor
../../../../src/cas/generic/casPVI.h:44: error: expected class-name before
?.? token
../../../../src/cas/generic/casPVI.h:44: error: expected `{' before ?.?
token
../../../../src/cas/generic/casPVI.h:44: error: expected unqualified-id before
?.? token
../../../../src/cas/generic/casPVI.h:100: error: invalid use of undefined type
?class casPVI?
../../../../src/cas/generic/casdef.h:111: error: forward declaration of ?class
casPVI?
../../../../src/cas/generic/casPVI.h: In member function ?caServerI*
casPVI::getPCAS() const?:
../../../../src/cas/generic/casPVI.h:102: error: invalid use of undefined type
?const class casPVI?
../../../../src/cas/generic/casdef.h:111: error: forward declaration of ?const
class casPVI?
../../../../src/cas/generic/casPVI.h: At global scope:
../../../../src/cas/generic/casPVI.h:105: error: invalid use of undefined type
?class casPVI?
casPVI?
../../../../src/cas/generic/casPVI.h: In member function ?const
gddEnumStringTable& casPVI::enumStringTable() const?:
../../../../src/cas/generic/casPVI.h:107: error: invalid use of undefined type
class casPVI?
../../../../src/cas/generic/casPVI.h:110: error: invalid use of undefined type
?class casPVI?
casPVI?
../../../../src/cas/generic/casPVI.h: In member function ?casPV*
casPVI::apiPointer()?:
../../../../src/cas/generic/casPVI.h:112: error: invalid use of undefined type
?class casPVI?
casPVI?
../../../../src/cas/generic/inBuf.h: At global scope:
../../../../src/cas/generic/inBuf.h:49: warning: ?class inBufClient? has
../../../../src/cas/generic/outBuf.h:50: warning: ?class outBufClient? has
../../../../src/cas/generic/chanIntfForPV.h:44: warning: ?class
casChannelDestroyFromPV? has virtual functions but non-virtual destructor
../../../../src/cas/generic/chanIntfForPV.h: In member function ?casMonitor*
chanIntfForPV::removeMonitor(casPVI&, ca_uint32_t)?:
../../../../src/cas/generic/chanIntfForPV.h:78: error: invalid use of undefined
type ?class casPVI?
casPVI?
../../../../src/cas/generic/chanIntfForPV.h: In member function ?void
chanIntfForPV::removeSelfFromPV(casPVI&, tsDLList<casMonitor>&)?:
../../../../src/cas/generic/chanIntfForPV.h:84: error: invalid use of undefined
type ?class casPVI?
casPVI?
../../../../src/cas/generic/casChannelI.h: In member function ?const
gddEnumStringTable& casChannelI::enumStringTable() const?:
../../../../src/cas/generic/casChannelI.h:98: error: invalid use of undefined
type ?class casPVI?
casPVI?
../../../../src/cas/generic/casChannelI.h: In member function ?void
casChannelI::installIntoPV()?:
../../../../src/cas/generic/casChannelI.h:103: error: invalid use of undefined
type ?class casPVI?
casPVI?
casChannelI::clearOutstandingReads()?:
../../../../src/cas/generic/casChannelI.h:108: error: invalid use of undefined
type ?class casPVI?
casPVI?
casChannelI::installIO(casAsyncIOI&)?:
../../../../src/cas/generic/casChannelI.h:134: error: invalid use of undefined
type ?class casPVI?
casPVI?
casChannelI::uninstallIO(casAsyncIOI&)?:
../../../../src/cas/generic/casChannelI.h:139: error: invalid use of undefined
type ?class casPVI?
casPVI?
make[4]: *** [casCoreClient.o] Error 1
make[4]: Leaving directory
`/usr/src/R3.14.7/base-3.14.7/src/cas/build/O.linux-x86'
make[3]: *** [install.linux-x86] Error 2
make[3]: Leaving directory `/usr/src/R3.14.7/base-3.14.7/src/cas/build'
make[2]: *** [build.install] Error 2
make[2]: Leaving directory `/usr/src/R3.14.7/base-3.14.7/src/cas'
make[1]: *** [cas.install] Error 2
make[1]: Leaving directory `/usr/src/R3.14.7/base-3.14.7/src'
make: *** [src.install] Error 2
I cannot seem to find any patches or advice for these errors and am at a
complete loss.
Can anybody help?!
Many thanks
Marcelo
Re: Base 3.14.7 build error on SUSE machine Ralph Lange
Re: Base 3.14.7 build error on SUSE machine Andrew Johnson
Prev: Re: Alarm in Epics Kay-Uwe Kasemir
Next: Re: Base 3.14.7 build error on SUSE machine Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Alarm in Epics Liyu, Andrei
