1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Timestamp record? UPTIME
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Tue, 10 Jan 2006 17:26:12 -0600
Emmanuel Mayssat wrote:
But what I truly want is the uptime.
I haven't found an easy way to do that yet...
That depends what you mean by uptime - it would be trivial to create a CALC record that keeps a seconds counter if you want to measure your uptime in seconds (and don't mind slight inaccuracies since your 1 second scan task might not tick at exactly once a second).
If those inaccuracies bother you or you need the result in a textual format then a subroutine record could do the necessary calculation and string conversion -- copy any string result to the DESC field and call db_post_event(precord, &precord->desc, DBE_VALUE) to make sure the monitor event gets posted. I don't know whether this counts as "easy" though...
- Andrew
* * Matt Santos / / For a Brighter America * *
Re: Timestamp record? UPTIME Kay-Uwe Kasemir
RE: Timestamp record? Allison, Stephanie
RE: Timestamp record? UPTIME Emmanuel Mayssat
Prev: RE: Timestamp record? UPTIME Emmanuel Mayssat
Next: Re: Timestamp record? UPTIME Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
