1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: vxstats for Epics 3.13.8
To: [email protected]
Date: Mon, 16 Jan 2006 23:54:49 +0100
On Monday 16 January 2006 20:17, Andrew Johnson wrote:
> liushu wrote:
> >    I need vxStats for Epics3.13.8.Where can I get it?
> Are you aware that there is a version of vxStats already included in
> Base R3.13.8?  It was unbundled for the R3.14.x series, but is usable
> in the earlier versions as is.
Note that this version of vxStats calls memPartInfoGet() which is well
known to (at least in VxWorks 5.2 and 5.4.3 (tornado 2.0.2)) contain a
serious bug that might corrupt the heap free list and cause
intermittent IOC crashes. This happens the more frequently, the more
the IOC allocates/deallocates memory at runtime. Particularly, the 3.13
base version of vxStats should not be combined with using a vxi-11
driver based on VxWorks RPC implementation (i.e. the 3.13. GPIB
driver).
I have a simple test routine that randomly allocates and deallocates
memory blocks of different sizes. Running this in a task on an IOC
together with a periodically scanned memory statistics record reliably
crashes the IOC after a short time (less than a minute, IIRC).
The easiest fix is to replace all calls to memPartInfoGet() with direct
accesses to the members of the MEM_PART structure (which of course must
be mutex guarded using the semaphore that is also part of this
structure). It seems that the statistics data in there are
automatically kept up-to-date, at least in VxWorks 5.4.3. I have
recently created a patched version of the 3.13.9 version of vxStats
that I can make available for download if people are interested.
See also: http://www.xs4all.nl/~borkhuis/vxworks/vxw_pt5.html#5.4A
Ben
Re: vxstats for Epics 3.13.8 Benjamin Franksen
vxstats for Epics 3.13.8 liushu
Re: vxstats for Epics 3.13.8 Andrew Johnson
Prev: Re: vxstats for Epics 3.13.8 Andrew Johnson
Next: Re: vxstats for Epics 3.13.8 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
