1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vxStats
To: Liu Shu <[email protected]>, tech talk <[email protected]>
Date: Tue, 17 Jan 2006 08:35:47 -0500
On Jan 15, 2006, at 23:08 , Liu Shu wrote:
Hi Kay:
Thank you for you help.
Here I directly use the vxStatsApp for my IOC.Whan I run st.cmd in ioc
console.I got the results below:
</home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest/st.cmd
# Example vxWorks startup file
#Following must be added for many board support packages
#cd <full path to target bin directory>
cd "/home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest"
value = 0 = 0x0
< cdCommands
startup = "/home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest"
startup = 0x1ffe8c0: value = 15535248 = 0xed0c90 = prsrv_cast_client + 0x58
appbin = "/home/liushu/epicsinstall/vxStats/vxStats/bin/ppc604_long"
appbin = 0x1ffe848: value = 15535176 = 0xed0c48 = prsrv_cast_client + 0x10
#nfsMount "ics-srv02", "/ade/epics/iocTop/R3.13.7/front_end/3-1","/ bootBase"
#nfsMount "ics-srv02", "/sns/ADE/home/carl/vxStats/3-1", "/startup"
#nfsMount "ics-srv02", "/sns/ADE/home/carl/vxStats/3-1", "/stats"
#< ../nfsCommands
#ld < /bootBase/bin/ppc603/epicsArchLd.o
cd appbin
value = 0 = 0x0
ld < iocCore
value = 33549096 = 0x1ffeb28 = pCaBucket + 0x38
ld < seq
value = 10908600 = 0xa673b8
ld < vxStatsLib
value = 10656984 = 0xa29cd8 = ca_server_port + 0x78
#epicsArchLd("/bootBase/bin/%s/iocCore");
#epicsArchLd("/bootBase/bin/%s/bootBaseLib");
#epicsArchLd("/bootBase/bin/%s/seq")
#dbLoadDatabase("/bootBase/dbd/bootBase.dbd");
iocLogDisable =1
iocLogDisable = 0x871634: value = 1 = 0x1
#epicsArchLd("/startup/bin/%s/vxStatsLib");
cd startup
value = 0 = 0x0
dbLoadDatabase("../../src/base.dbd")
liushu:bash: line 1:
/home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest/?value =
filename="../db-LexRoutines.c" line1 number=236
S_errno = 0x_EBUSY dbRead offffffffpening file .. = /../src/base.dbd
pnivxi_func + 0xfe00124f
dbLoadDatabase("../../dbd/vxStats.dbd")
Error " record type not found"  Last token ")"
input line: device(stringin,INST_IO,devStringinStats,"VX stats")
   in: file ../../dbd/vxStats.dbd line 1757
   in: file ../../dbd/vxStats.dbd line 3514
db_parse returned -1
value = -1 = 0xffffffff = pnivxi_func + 0xfe00124f
dbLoadTemplate("../../src/Db/ioc.substitutions")
/home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest/? dbLoadTemplate:
error opening sub file ../../src/Db/ioc.substitutions
iocInit
Star### ting iocInit
@(#)EPICS IOC CORE built on Jan 18 2005
### @(#)Version R3.13.8 $2003/02/04 19:59:44$
Failed to set time from Unix server
value = 0 = 0x0
 I edited directly the st.cmd of vxStats.The result shows me there's
something wrong while loading dbd files.
Right. Looks like the stringin record, which could be found in EPICS base, is not.
When I create a new application as what you said.There's no testInclude.dbd
file but exampleInclude.dbd.
That's the one.
Then I create the testInclude.dbd and include
vxStats.dbd.And need I copy those dbd files into my new applicaions,such as
the vxStats.dbd?
No copy should be necessary.
By adding something like
 VX_STATS = /path/to/vxStats
to your apps' configure/RELEASE file
(config/RELEASE for R3.13),
the necessary files are found without
having to copy them into your app.
  You said "edit my_great_apps/testApp/src/Makefile* to include the
library".Do you mean edit the src/Makefile.Vx and add:
  LIBOBJS += $(VX_STATS)/bin/ppc604_long/vxStatsLib
  And I should also copy those vxstats db files to my own
applications,right?
Because VX_STATS is defined in RELEASE, you can use that variable in LIBOBJS += $(VX_STATS)/bin/ppc604_lo.... without need to copy.
-Kay
vxStats liushu
Re: vxStats Kay-Uwe Kasemir
Prev: Re: vxstats for Epics 3.13.8 Benjamin Franksen
Next: Beam Extracted from SNS Ring Gurd, David P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: vxStats Kay-Uwe Kasemir
Next: RE: vxStats Gurd, Pamela A.
