1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: vxStats
To: "Kasemir, Kay" <[email protected]>, Liu Shu <[email protected]>, tech talk <[email protected]>
Date: Tue, 17 Jan 2006 09:50:56 -0500
The vxStats we are using in 3.14 uses features of the stringin record
that were only added in 3.14.5 or so.  It will not work under 3.13.
    Pam Gurd.
> -----Original Message-----
> From: Kay-Uwe Kasemir [mailto:[email protected]]
> Sent: Tuesday, January 17, 2006 8:36 AM
> To: Liu Shu; tech talk
> Subject: Re: vxStats
> On Jan 15, 2006, at 23:08 , Liu Shu wrote:
> > Hi Kay:
> >    Thank you for you help.
> >    Here I directly use the vxStatsApp for my IOC.Whan I run st.cmd
> > in ioc
> > console.I got the results below:
> >   </home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest/st.cmd
> > # Example vxWorks startup file
> > #Following must be added for many board support packages
> > #cd <full path to target bin directory>
> > cd "/home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest"
> > value = 0 = 0x0
> > < cdCommands
> > startup =
> > startup = 0x1ffe8c0: value = 15535248 = 0xed0c90 =
> > prsrv_cast_client + 0x58
> > appbin = "/home/liushu/epicsinstall/vxStats/vxStats/bin/ppc604_long"
> > appbin = 0x1ffe848: value = 15535176 = 0xed0c48 = prsrv_cast_client
> > + 0x10
> > #nfsMount "ics-srv02", "/ade/epics/iocTop/R3.13.7/front_end/3-1","/
> > bootBase"
> > #nfsMount "ics-srv02", "/sns/ADE/home/carl/vxStats/3-1", "/startup"
> > #nfsMount "ics-srv02", "/sns/ADE/home/carl/vxStats/3-1", "/stats"
> > #< ../nfsCommands
> > #ld < /bootBase/bin/ppc603/epicsArchLd.o
> > cd appbin
> > value = 0 = 0x0
> > ld < iocCore
> > value = 33549096 = 0x1ffeb28 = pCaBucket + 0x38
> > ld < seq
> > value = 10908600 = 0xa673b8
> > ld < vxStatsLib
> > value = 10656984 = 0xa29cd8 = ca_server_port + 0x78
> > #epicsArchLd("/bootBase/bin/%s/iocCore");
> > #epicsArchLd("/bootBase/bin/%s/bootBaseLib");
> > #epicsArchLd("/bootBase/bin/%s/seq")
> > #dbLoadDatabase("/bootBase/dbd/bootBase.dbd");
> > iocLogDisable =1
> > iocLogDisable = 0x871634: value = 1 = 0x1
> > #epicsArchLd("/startup/bin/%s/vxStatsLib");
> > cd startup
> > value = 0 = 0x0
> > dbLoadDatabase("../../src/base.dbd")
> > liushu:bash: line 1:
> > /home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest/?value =
> > filename="../db-LexRoutines.c" line1 number=236
> > S_errno = 0x_EBUSY dbRead offffffffpening file .. = /../src/base.dbd
> > pnivxi_func + 0xfe00124f
> > dbLoadDatabase("../../dbd/vxStats.dbd")
> > Error " record type not found"  Last token ")"
> > input line: device(stringin,INST_IO,devStringinStats,"VX stats")
> >    in: file ../../dbd/vxStats.dbd line 1757
> >    in: file ../../dbd/vxStats.dbd line 3514
> > db_parse returned -1
> > value = -1 = 0xffffffff = pnivxi_func + 0xfe00124f
> > dbLoadTemplate("../../src/Db/ioc.substitutions")
> > dbLoadTemplate:
> > error opening sub file ../../src/Db/ioc.substitutions
> > iocInit
> > Star###  ting iocInit
> > @(#)EPICS IOC CORE built on Jan 18 2005
> > ###  @(#)Version R3.13.8 $2003/02/04 19:59:44$
> > Failed to set time from Unix server
> > value = 0 = 0x0
> >  I edited directly the st.cmd of vxStats.The result shows me there's
> > something wrong while loading dbd files.
> Right. Looks like the stringin record, which could be found
> in EPICS base, is not.
> >  When I create a new application as what you said.There's no
> > testInclude.dbd
> > file but exampleInclude.dbd.
> That's the one.
> > Then I create the testInclude.dbd and include
> > vxStats.dbd.And need I copy those dbd files into my new
> > applicaions,such as
> > the vxStats.dbd?
> No copy should be necessary.
> By adding something like
>   VX_STATS = /path/to/vxStats
> to your apps' configure/RELEASE file
> (config/RELEASE for R3.13),
> the necessary files are found without
> having to copy them into your app.
> >   You said "edit my_great_apps/testApp/src/Makefile* to include the
> > library".Do you mean edit the src/Makefile.Vx and add:
> >   LIBOBJS += $(VX_STATS)/bin/ppc604_long/vxStatsLib
> >   And I should also copy those vxstats db files to my own
> > applications,right?
> Because VX_STATS is defined in RELEASE,
> you can use that variable in
>    LIBOBJS += $(VX_STATS)/bin/ppc604_lo....
> without need to copy.
> -Kay
Prev: Beam Extracted from SNS Ring Gurd, David P.
Next: octave interface D. Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: vxStats Kay-Uwe Kasemir
Next: EPICS CA security with the motorRecord? Ernest L. Williams Jr.
