1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ASYN Question
To: "John Dobbins" <[email protected]>, <[email protected]>
Date: Fri, 20 Jan 2006 19:18:29 -0600
John,
Yes, you are correct.  Your GPIBCVTIO routine executes in the port thread for that asyn port, and it blocks all other I/O for that port.  You are guaranteed that all I/O you do is "atomic" and no other I/O can interfere, as long as all other I/O to that device is also using asyn.
Sent: Fri 1/20/2006 6:26 PM
To: [email protected]
Subject: ASYN Question
Dear All,
I have a serial device for which I am trying to implement Device Support
using ASYN. This is an EOS-901 from Eye on Science, a VAC ION Pump
controller.
There is one parameter, the Soft_Current_Trip_Level that requires the
following procedure:
1) Send:  "UHV99S"           (constant string)
2) Read:  "Enter Alarm Limit\r"
(the unit will now wait until a new value is sent as follows)
3) Send:  "0.000001\r"       (value dependent string)
4) Read:  "new limit=1.00e-06\r"
I can write a GPIBCVTIO routine that will accomplish all four
steps. Am I correct in assuming that no other gpibCmd for this device will
process while my gpibCmd with the GPIBCVTIO routine is executing? i.e. the four
steps cannot be interrupted by a request from some other periodically scanned
record associated with this device?
John Dobbins
Laboratory for Elementary Particle Physics
Cornell University
Ithaca, NY
Prev: ASYN Question John Dobbins
Next: Re: Timestamp record? UPTIME Miroslaw Dach
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Agilent 34401A DVM support? Eric Norum
