1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Timestamp record? UPTIME
To: Ralph Lange <[email protected]>
Cc: Steven Banks <[email protected]>, <[email protected]>
Date: Mon, 23 Jan 2006 11:39:24 +0100 (CET)
Hi Ralph,
	I have installed the PC monitoring project under the web server in
SLS/PSI. The tar.gz  file could be found under
http://epics.web.psi.ch/software/pcmon/PC-MONITOR-EPICS3.14.7.tar.gz
PC-MONITOR-EPICS3.14.7/README file explains how to deal with that project.
Best Regards
Mirek
On Fri, 20 Jan 2006, Ralph Lange wrote:
> Hi Steven, hi Marek,
> would you be so kind to add this module with contact and download info
> to the soft support database on the EPICS web server?
> After Mirek sent such an impressive screen shot I'm sure there's a
> broader interest in using that system....
> Thanks a lot!
> Ralph
> Miroslaw Dach wrote:
> >Dear All,
> >	Here in SLS/PSI we use for last 8 months the PCs monitoring
> >system which is based on EPICS and Linux.
> >Please find in the attachment the screen dump with all of the monitored
> >parameters.
> >Best Regards
> >Mirek
> >>Title: Message
> >>At the Australian Synchrotron we've written a device support routine
> for
> >>our Redhat Linux IOCs which allows various statuses, including the
> >>machine
> >>and IOC uptime, to be monitored via PVs.
> >>If you wish, I can sent you the source code, including a small demo
> >>application.
> >>Dr. Steven M. Banks . Control Systems Engineer
> >>Australian Synchrotron Project
> >>Major Projects Victoria
> >>800 Blackburn Road
> >>CLAYTON VIC 3168
> >>tel: +613 8540 4103
> >>fax: +613 8540 4200
> >>mailto:[email protected]
> >>http://www.synchrotron.vic.gov.au
          Miroslaw Dach ([email protected]) - SLS/Controls Group
                PSI - Paul Scherrer Institut CH-5232 Villigen
Re: Timestamp record? UPTIME Ralph Lange
Prev: RE: ASYN Question Mark Rivers
Next: Agilent 34401A DVM support? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Timestamp record? UPTIME Ralph Lange
Next: EPICS Patriarch Succumbs to Stronger Call Ned Arnold
