1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building EPICS ArchiveViewer
To: [email protected]
Cc: Sergei Chevtsov <[email protected]>
Date: Tue, 14 Feb 2006 08:33:55 -0600
I also tried compiling simple Java program with ant, and so far, I
have been successful (I followed the first part of "Apache ant
Demystified"
http://www.sitepoint.com/print/apache-ant-demystified).
On 2/13/06, Jiro Fujita <[email protected]> wrote:
> I have tried ArchiveViewer via Web start, and it works well.
> Meanwhile, I have tried all the sort of things, and I was able to
> compile simple Java program (with javac.  I haven't tried with ant,
> yet).
> On 2/13/06, Sergei Chevtsov <[email protected]> wrote:
> > Hi!
> > I have never seen Java trying to allocate almost 1 GB of memory before.
> > Are you able to run ArchiveViewer via Web start?
> > http://ics-web1.sns.ornl.gov/archive/viewer/web_start/archiveviewer.jnlp
> > If so, I would just recommend to build some other Java program. Please,
> > be kind to report your results.
> > Greetings,
> > Sergei Chevtsov
> > Jiro Fujita wrote:
> > >Hello, my colleague Yury Gorbunov and I have been trying to build
> > >EPICS ArchiveViewer 1.0.4 and getting an error message like this:
> > >%> ant configure_jsp
> > >Buildfile: build.xml
> > >-create_build_dir:
> > >build_all:
> > >    [javac] Compiling 842 source files to
> > >/home/sysuser/epics/archive_viewer-1-0-4/build
> > >    [javac] jc1: out of memory allocating 1342179073 bytes after a
> > >total of 548864 bytes
> > >BUILD FAILED
> > >file:/home/sysuser/epics/archive_viewer-1-0-4/build.xml:21: Compile
> > >failed; see the compiler error output for details.
> > >Total time: 1 second
> > >We have spent several hours and cannot figure out what we are doing
> > >wrong.  It is on a Scientific Linux 3.0.5 with JDK 5.0 Update 6.  We
> > >have $CLASSPATH set to tools.jar and rt.jar provided by JDK 5.0, and
> > >$JAVA_HOME set to /usr/java/jdk1.5.0_6.
> > >Does anybody have suggestions??
building EPICS ArchiveViewer Jiro Fujita
Re: building EPICS ArchiveViewer Sergei Chevtsov
Re: building EPICS ArchiveViewer Jiro Fujita
Prev: Re: Channel Archiver on Scientific Linux Gasper Pajor
Next: Re: labCA crashes with bad PV Dennis Nicklaus
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: building EPICS ArchiveViewer Jiro Fujita
Next: Re: building EPICS ArchiveViewer Jiro Fujita
