I've succeeded in puting the [etx] on the end of lines but I get the literal string "\002" instead of [stx] at the start, so I'm looking for help! The record which successfully puts [etx] in line termination is: record(stringout,"scu2CCS:shutter:coms:txCmd") { field(DESC,"string output record") field(SCAN,"Passive") field(PINI,"YES") field(PHAS,"0") field(EVNT,"0") field(DTYP,"Ascii SIO") field(DISV,"1") field(SDIS,"0.000000000000000e+00") field(DISS,"NO_ALARM") field(PRIO,"LOW") field(FLNK,"0.000000000000000e+00") field(VAL,"\003\r\n") field(DOL,"\003\r\n") field(OMSL,"closed_loop") field(OUT,"@/pty/shutterM <writeCmt %s>") field(SIOL,"0.000000000000000e+00") field(SIML,"0.000000000000000e+00") field(SIMS,"NO_ALARM") field(IVOA,"Continue normally") field(IVOV,"") } and the record which fails to put [stx] in the command line is: record(stringin,"scu2CCS:shutter:test") { field(DESC,"string input record") field(SCAN,"10 second") field(PINI,"NO") field(PHAS,"0") field(EVNT,"0") field(DTYP,"Ascii SIO") field(DISV,"1") field(SDIS,"0.000000000000000e+00") field(DISS,"NO_ALARM") field(PRIO,"LOW") field(FLNK,"0.000000000000000e+00") field(VAL,"string") field(INP,"@/pty/shutterM <\002SUI><%s>") field(SIOL,"0.000000000000000e+00") field(SIML,"0.000000000000000e+00") field(SIMS,"NO_ALARM") } TIA -- Ian A Smith Telephone: +44 (0) 131 668 8255 Royal Observatory Fax: +44 (0) 131 668 8314 Blackford Hill Web: http://www.roe.ac.uk/ Edinburgh EH9 3HJ UK
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
